Welcome to the RAS Solution Forums HEC-RAS Help dam breach hydrograph
  • #6121
    I need to generate dam breach hydrograph for the moraine dam in HEcras 4.1. What are the inputs that are most governing?
    #9961
    Usually the breach formation time has the most impact on the peak of the breach outflow hydrograph. However, because there is large uncertainty in all the breach parameters, a sensitivity analysis is a good idea to determine which parameter affects the flooding and travel time the most for your situation. Suggest you look at HEC TD-39 “Using HEC-RAS for Dam Break Studies” for more info.
