Welcome to the RAS Solution Forums HEC-RAS Help culverts with variable invert elevation and barrels
  • This topic has 2 replies, 415 voices, and was last updated 13 years ago by Anonymous.
  • #5348
    Thank you Christ G for your suggestion on how to simulate weirs with changing height and length. I have a similar question on culverts. The number of circular barrels and invert elevation of culverts may change over time. One way I can think of is to use overflow gates with closed top to mimic this kind of culverts. Just wonder if anybody has better idea?
    #8540
    Using drop gates to model a culvert that changes invert elevation would be the simple approach, if that gives good enough answers.
    Alternately, you could put it a bunch of different culverts at different heights (each one would have to be a separate culvert group). You could then use the Advanced Rules (see User’s Manual) to control which culverts have flow. The Rules allow you to set a given culvert group to have a zero flow.
    #8541
    Keymaster
    Just a quick head’s up that there is a nice presentation on the use of Rules posted at RASModel.com. http://hecrasmodel.blogspot.com/2013/09/advanced-rules-for-unsteady-flow.html
    Enjoy!
    @RASModel
