Welcome to the RAS Solution › Forums › HEC-RAS Help › culvert upstream and down stream opening is not same
  • #6799
    sthsajan
    how do we create a model if the culvert opening is different in upstream and downstream?
    upsteam 34 ft wide and down stream 6 ft width
    #11225
    Chad Ballard
    Have you thought about a rating curve instead? The approach that I would probably use would be to develop a rating curve outside of RAS then apply it to an inline structure to represent the culvert. Would be a tricky thing as the culvert changes from inlet to outlet control while I have not modeled a culvert like yours, I have used this approach to model complex structures that do not exactly fit the standard inputs.
    #11226
    Just like many of your posts, the answer would be lidded cross sections.
    #11227
    sthsajan
    I am thinking to make a lidded cross section since I have a cross section in upstream and down stream and I will get few cross section with in the culvert with interpolation so I can get the real opening of the culvert.
    just wondering will it give me the correct water flow level in steady flow analysis?
