Welcome to the RAS Solution Forums HEC-RAS Help Culvert solution criteria – Inlet or outlet control
  • This topic has 0 replies, 1 voice, and was last updated 3 years ago by Mo.
  • #16950
    Mo
    I am building a 2d HEC-RAS model of a small bridge and the replacement option is a culvert series. I have the computed flow control option selected so the program is calculating both inlet and outlet control answers and then selecting the higher of the two, is there a way to see which option the program ended up using?
    Thanks!
