Welcome to the RAS Solution Forums HEC-RAS Help Culvert Modeling at a Junction
  • This topic has 1 reply, 268 voices, and was last updated 7 years ago by Anonymous.
  • #7201
    I am new to HEC-RAS and currently working on a project to model a causeway that starts in a tributary and enters a larger stream. The causeway then travels upstream to an island in the larger river. In order to model the culverts needed I believe I need to reference cross sections in multiple reaches. Is there any possible way to do this or am I better off modeling the causeway separately for tributary and larger stream somehow?
    #12051
    If you are doing this in 1D, you might want to consider 2D if you have terrain and the time. Although this would be trickier for a new RAS user.
    Without knowing more about your particular problem, it is hard to say too much. If your culverts start in one reach and end in a different reach, you may be able to do that using a lateral structure.
    It might also be possible to model your culverts as a normal cross section with a lid using the Preissmann slot option.
