Welcome to the RAS Solution Forums HEC-RAS Help Culvert & Deck / Roadway Help
  • #5795
    TonyL
    Hi
    Thank you for your helpfull forum!!
    I am new to Hec-Ras and feel that I should have found the solution to this in all the literature I have read this far, but alas . . . .
    I am struggling to get a culvert and deck/roadway correct. Below is a screen shot of the profile plot after running a steady flow analysis:
    From this you can see that the upstream embankment of the roadway is going the wrong way?
    Below are the culvert and roadway input screens:
    Your help will be much appreciated.
    Tony
    #9311
    Marulke
    Tony,
    I am not sure exactly what your question is, but after looking at your screenshots I have some comments:
    1) The bottom of the cross section at the upstream (US) end of the culvert is well above the culvert entrance. This is probably an error?
    2) The high chord of the roadway at the US end is at approximately the same height as the US cross section. This is not impossible, but I had expected the roadway to be well above the ground level.
    3) Does the distance from the US cross section and the length the culvert fit with the distance between the US and DS cross section? They dont have to be equal, but the culvert appears to be placed to far downstream.
    Suggestion: Check your geometry again.
    Hope this helps.
    Marulke
    #9312
    KellyHH
    In the deck editor, it looks like you’re using the same stationing for both the upstream and downstream sides; however, from what I can see of the bounding cross sections, the channel has different stationing in each location (~100 upstream, ~20 downstream).
    The likely fix is to adjust the stationing of the upstream bridge deck to center it on the upstream channel area. That is, your upstream and downstream bridge decks will not have the same stationing, and may not have the same elevations, or even the same number of points.
    #9313
    TonyL
    Return-Path: <77tonyl@gmail.com>
    X-Original-To: ml-node+s1091112n1646h24@n5.nabble.com
    Delivered-To: ml-node+s1091112n1646h24@n5.nabble.com
    Received: from mail-la0-f47.google.com (mail-la0-f47.google.com [209.85.215.47])
    by mbob.nabble.com (Postfix) with ESMTP id 2AA2BD1E344
    for ; Tue, 19 May 2015 03:10:23 -0700 (PDT)
    Received: by lagr1 with SMTP id r1so15682622lag.0
    for ; Tue, 19 May 2015 03:10:14 -0700 (PDT)
    d=gmail.com; s=20120113;
    h=mime-version:references:in-reply-to:from:date:message-id:subject:to
    :content-type;
    bh=h5fa4fJojI2gkELh8C5YbcF1CC/DqRlVset7dI1pjko=;
    b=to/aYwcl6TWXgBw2+wEmr3bqrtHj3DV1SLlY+SMybfbsqnycPwtih8Hl8xysHpXpAA
    AX9TdKpi7KOJgpNT/4vjI1D5gzvleP6CGaoAsV83OHlO3yfOz9YiXN0Yv64L/rm9eLrE
    O91DCGAl9SMUzy/LllSEYUCGPoeIr75YojqxYUVdKQ44bbifHdehlWCtwF7azjZyPbVv
    JHZiadQcvomwWRSIjG/0jUj8UBHefG3gNamsl9wBDfC3zV1MLw61YBrznbbuqrM/DkQ/
    ernnvDKgaQL1Rdjl9l8x6qxq9kCOX8es+4yD9YC1H6dUvplV99NYf27JEs/JZV2DtKy/
    EKxQ==
    X-Received: by 10.112.218.67 with SMTP id pe3mr19929747lbc.53.1432030213858;
    Tue, 19 May 2015 03:10:13 -0700 (PDT)
    MIME-Version: 1.0
    References: <1431424362685-1640.post@n5.nabble.com> <1431536974324-1646.post@n5.nabble.com>
    In-Reply-To: <1431536974324-1646.post@n5.nabble.com>
    Date: Tue, 19 May 2015 10:10:13 +0000
    Message-ID:
    Subject: Re: Culvert & Deck / Roadway Help
    To: “KellyHH [via HEC-RAS Help]”
    Content-Type: multipart/alternative; boundary=001a11c31d1234695305166c84ce
    –001a11c31d1234695305166c84ce
    KellyHH you nailed it! Thank you. It would seem that the upstream bridge
    deck stationing must be relative to the upstream section and the downstream
    one relative to the downstream section.
    Tony
    On Wed, May 13, 2015 at 7:09 PM KellyHH [via HEC-RAS Help] < ml-node+s1091112n1646h24@n5.nabble.com> wrote:
    > both the upstream and downstream sides; however, from what I can see of t=
    he
    > downstream bridge decks will not have the same stationing, and may not ha=
    ve
    > below:
    > http://hec-ras-help.1091112.n5.nabble.com/Culvert-Deck-Roadway-Help-tp164=
    0p1646.html
    > To unsubscribe from Culvert & Deck / Roadway Help, click here
    =3Dunsubscribe_by_code&node=3D1640&code=3DNzd0b255bEBnbWFpbC5jb218MTY0MHwtM=
    jc5NjM3NjU5>
    > NAML
    ace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers=
    %21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_em=
    ail%21nabble%3Aemail.naml>
    KellyHH you nailed it!=C2=A0 Thank you.=C2=A0 It would see=
    m that the upstream bridge deck stationing must be relative to the upstream=
    section and the downstream one relative to the downstream section.
    Tony
    On Wed, May =
    13, 2015 at 7:09 PM KellyHH [via HEC-RAS Help] <ml-node+s1091112n1646h24@n5.nabble.com<= /a>> wrote:
    8ex;border-left:1px #ccc solid;padding-left:1ex">
    In the deck editor, it looks like you're using the same stationing for=
    both the upstream and downstream sides; however, from what I can see of th=
    e bounding cross sections, the channel has different stationing in each loc=
    The likely fix is to adjust the stationing of the upstream bridge d=
    eck to center it on the upstream channel area.=C2=A0 That is, your upstream=
    and downstream bridge decks will not have the same stationing, and may not=
    =09
    =09
    =09
    =09
    To unsubscribe from Culvert & Deck / Roadway Help, click here.
    NAML
    –001a11c31d1234695305166c84ce–
