Welcome to the RAS Solution Forums HEC-RAS Help Creating the reaches exact lenght
  • #5993
    Adnan
    hi members .
    i am very new to HEc- Ras
    i want to create the 3 reaches of exact 1 km . is that possible to create by using just simple put “1” in the box
    and also i want to add x-sections manually by putting the nodes .
    need asap help
    Regards
    #9660
    You could define a reach exactly 1 km (1000m) long by describing the upstream-most and downstream-most sections 1 km apart. Then you can use the interpolation feature of RAS to insert evenly-spaced cross sections within that reach.
    #9661
    Adnan
    thanx michael for the help
    also is it possible to add manually the x-sections ?
