I am having trouble importing terrain into HEC-RAS 5.0.3.
Here are my steps:
-Created surface in Civil3D 2017 with LiDAR .las data imported into point cloud.
-Exported surface from Civil3D as geotiff with 1.0 ft grid spacing (5GB file size).
-Import geotiff into SAGA GIS using Import/GDAL/Import Raster.
-Export to ESRI .flt file using SAGA GIS. Adjusted the .hdr file in notepad so HEC-RAS recognizes it. (Note: This step I also have tried using ArcGIS import/export functions and get the same result below)
Next I setup a new HEC-RAS file, set the projection file and go to import the terrain and get this message:
Any ideas? I’ve had success with running a 2D flow model before, although the terrain in that one was only 1GB and was on a Windows 7 machine.
