Welcome to the RAS Solution Forums HEC-RAS Help Courant and Froude numbers for 2D area
  • #6292
    Hi everyone.
    I would like to know if there is possibility to see Courant number for 2D area after simulation (max value of C. number). Or even better if there is possibility to see spatial distribution of Courant number (for every mesh in 2D area). The same for Froude number. Thank you.
    #10279
    This is not possible inside of HEC-RAS. You could do some raster calcs in GIS to come up with the Courant or Froude based on the output rasters or if you could take the output from the hdf file directly.
    #10280
    Thanks for reply. I had same idea about GIS map algebra.
