Welcome to the RAS Solution › Forums › HEC-RAS Help › converting .sdf file (geometry) to shp file
Hi, how can I convert .sdf file (geometry file generated by HEC-RAS which includes all cross-sections information) to .shp file?
thank you
m
You would need to use HEC-GeoRAS.
What I would do though is use Mapper to export out the XS and other data as shp files.
Hi cameron, I tried with mapper but it doesn’t export elevation for all the surface lines in the XS. I did like that:
Please enter an answer in digits:
