Hello Chris,
Can you continue a HECRAS model simulation from the end point of a previous simulation? Or do I still need to re-run the model for the extended period?
I ran a flood simulation for 3 days (unsteady flow simulation with a constant flow value) and after checking out the result I feel that the model I should have let it run for one more day for model to stabilize as depth values were still increasing when simulation stops. Do I have to rerun the whole simulation again (which took a whole day) or can I somehow start from where the last simulation ended?
Thank you.
Regards,
-F
