Welcome to the RAS Solution Forums HEC-RAS Help Connecting 2D flow area and 1D reach
Viewing 11 posts - 1 through 11 (of 11 total)
  • #7258
    M. L. Harris
    I’m experiencing what appears to be some model instability at the interface of my 2D and 1D domains. I’m connecting an upstream 2D flow area to a downstream 1D reach because I have four bridges downstream. I’ve messed around with warmup, initial conditions, time step, increasing 1D/2D iterations, etc. but I’m getting sharp increases in velocity and a jump in WSE at the bounding XS. Has anyone troubleshooted a similar issue?
    #12144
    Ian Sharp
    We have run into this on several models. I’ve played with all the things you played with and also switching between Full Momentum and Diffusion Wave. I have found that the DW runs have much less of these types of issues while FM runs tend to have some strange velocity and WSE issues along any interface. I see in your cross section you have shallow flow on a terrace which is above the flow in the channel. I have seen this phenomena occur with the use of the FM equations in channelized flow conditions.
    We have had several models with fully channelized/contained flow that the 2D FM equations over-estimate water surface elevations and/or place water where a 1D model would not. That is to say, if you model the reach with a 1D model you will get a certain answer. Then if you model it with a 2D model with the FM equation set, the water surface will some times be 2-3 feet higher. So what may be happening in your situation is the 2D model is simply giving an answer that disagrees with the 1D model at this interface.
    I have not yet found a great answer for this issue. You can try to move the connection to a more favorable location and adjust some roughness values. I have not found much benefit in changing the grid size at the interface. Sometime the warmup will help, but not always. I suppose that as long as the model is not having a volume conservation issue that maybe the answer is to live with the problem and address it in the mapping.
    #12145
    M. L. Harris
    Thank you for the response and advice, very appreciative!
    I’ve only been running 2D in DW and not FM (I’ve been hesitant to try FM in light of the issues I’m having ).
    I tried moving the d/s end of my 2D area to the next 1D XS downstream but interestingly the problem propagated itself downstream – look at that velocity spike!
    I’ve considered scrapping the 1D domain and extending the 2D area downstream (WSE doesn’t reach the bridge decks in the events I’m simulating); but, it could take quite an effort to get the abutments and piers accurately represented in the terrain…
    #12146
    do you have the 1D/2D iterations option turned on?
    #12147
    M. L. Harris
    Hi, I have experimented with max 1D/2D iterations and have set it as high as 20 but the problem still persists.
    Some other tests I have tried:
    – Reduce grid cell size at 1D/2D interface (gradually decreased from 25’x25′ to 10’x10′ at interface)
    – Decrease computation time step (tested time steps ranging from 5 sec down to 1 sec)
    – Added warm up period
    – Modified Manning’s n at interface
    – Moved 1D/2D interface to next downstream XS in 1D reach
    – Tested different initial conditions (use of .rst file versus initial flow versus initial conditions ramp up)
    I have not yet experimented with time slicing, and have only run Diffusion Wave, not Full Momentum.
    #12148
    Scott Miller
    What happens when you vary the minimum flow tolerance? It looks like the water surface is a higher elevation on the 2D side of the interface. Do the water surfaces converge during 1D/2D iterations, or are there 1D/2D flow errors? How large, compared to the minimum flow tolerance?
    What do maps of velocity and Courant number reveal? The transition from 2D to 1D should be uniform. How well do the cross section, Manning number, and slope at the interface match upstream 2D channel characteristics?
    How persistent is the problem through the duration of the run?
    Full momentum can help identify problematic cells. Give it a try and pinpoint those cells. Keep in mind there may be superelevation at the outside of a bend.
    #12149
    M. L. Harris
    Hi Scott, these are great suggestions. I have not tried all of these yet, but will.
    I am currently using v5.0.7 defaults for water surface and volume tolerance. Maximum xsec wsel is 0.054 for my latest run; this occurred two XS’s downstream of my 1D/2D interface. At the interface, terrain and Manning’s n are identical.
    I am currently running steady flows to troubleshoot this issue, so the problem is persistent throughout the run (currently 36 hrs at 1 sec timestep). I am using a 12 hour initial conditions time and a ramp up fraction of 0.7.
    I will try FM next to see how the model behaves. Here are maps of velocity and Courant. Thanks again for your response.
    #12150
    Did you try extending the 2D model to the next downstream 1D XS?
    #12151
    M. L. Harris
    I did, and frustratingly, the issue jumped the to next downstream 1D XS as well.
    Velocity is mapped in these figures.
    #12152
    Looks like some instabilities. If you sent me the model I could play with it.
    #12153
    M. L. Harris
    Return-Path:
    by sloti1d2t14 (Cyrus 3.1.6-329-gf4aae99-fmstable-20190329v1) with LMTPA;
    Mon, 08 Apr 2019 15:40:26 -0400
    X-Cyrus-Session-Id: sloti1d2t14-1554752426-2266113-2-10687440007985247586
    X-Sieve: CMU Sieve 3.0
    X-Spam-known-sender: no
    X-Spam-score: 1.3
    X-Spam-hits: HTML_MESSAGE 0.001, ME_ZS_CLEAN -0.001, RCVD_IN_DNSWL_NONE -0.0001,
    SPF_HELO_PASS -0.001, SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en,
    BAYES_USED none, SA_VERSION 3.4.2
    X-Spam-source: IP=’40.107.78.131′,
    Host=’mail-eopbgr780131.outbound.protection.outlook.com’, Country=’US’,
    FromHeader=’com’, MailFrom=’com’, XOriginatingCountry=’US’
    X-Spam-charsets: plain=’us-ascii’, html=’us-ascii’
    by compute1.internal (LMTPProxy); Mon, 08 Apr 2019 15:40:26 -0400
    by mailmx.nyi.internal (Postfix) with ESMTP id A46AD60103
    for ; Mon, 8 Apr 2019 15:40:25 -0400 (EDT)
    id 2D7A530E517;
    1554752425; b=MO4ogjeKwHNdj2IGom6XOs2KhTDr4/tN3feKJzZbjDLGy43exz
    OhtGtlnYOuooXtzNEsanFjlJqOK70iv46Nl6d9wAlOBDn9gr9JINWrFwbBZOn4+c
    W96PD8ROER/d/+LGun/9P5/1HNSQwUn/+vICSC7IHzTthN5Pi0KD8da6aT9LOWlB
    v7wi24Ii9zKzPcDZPVWpLu+hBnNgSeR+ICPDnSNJZxdC+UWnm3uda/0t2wh7naB1
    qtxshSSiiwKGMa4/QewuMFXOpoSdLA04CWL8K1dqtlqr98a/MJdhtC8k1Fcfg/2c
    aXGngpM+vp1gJmsBNd5g1U/koWtzj+1A0rBQ==
    messagingengine.com; h=from:to:subject:date:message-id
    :references:in-reply-to:content-type:mime-version; s=fm2; t=
    1554752425; bh=4gVc8UarVWprQESYI8AGozgduslOVfRXpOWNYnaxd7U=; b=4
    9li67C6dBIUzzde9qgUqzdPMPUSsN6U0OfGnWKU5Ftv9UfzKoeZtW3TqdY6jd05H
    RmqjVWI7jlUa7Pw+ww1PhTo9pSfbJiq4QPKylFy9K3BwyK/XeCf51L8NSSqB++8O
    JsqF6ZdkpfyBlBJqiEg2kCtNE9phfr8QDAUOHilRZmR4zgi2/wpFKCRGYx5hb687
    /TOuvKlNXdMQXsb2MCZQdehl8BwTAYgHRm+hTEnybWnBjmUucNC86jRezoaSgSNJ
    pil8rWD37JAoH2OMmn0mysoV2xqz7jlFibhG3oa4XTsBZELXou3Z95VUMOrZnj/e
    adq2W69ux2LBmKorinn2w==
    ARC-Authentication-Results: i=1; mx4.messagingengine.com; arc=none (no signatures found);
    dkim=pass (1024-bit rsa key sha256) header.d=tetratech.com
    [email protected] header.b=e6svUf9n header.a=rsa-sha256
    header.s=selector1 x-bits=1024;
    dmarc=pass policy.published-domain-policy=quarantine
    (p=quarantine,d=none,d.eval=none) policy.policy-from=p
    header.from=tetratech.com;
    iprev=pass smtp.remote-ip=40.107.78.131
    (mail-eopbgr780131.outbound.protection.outlook.com);
    spf=pass [email protected]
    smtp.helo=NAM03-BY2-obe.outbound.protection.outlook.com;
    x-ptr=fail smtp.helo=NAM03-BY2-obe.outbound.protection.outlook.com
    policy.ptr=mail-eopbgr780131.outbound.protection.outlook.com;
    x-return-mx=pass header.domain=tetratech.com policy.is_org=yes
    (MX Record found);
    x-return-mx=pass smtp.domain=tetratech.com policy.is_org=yes
    (MX Record found);
    x-tls=pass smtp.version=TLSv1.2 smtp.cipher=ECDHE-RSA-AES128-SHA
    smtp.bits=128/128;
    x-vs=clean score=0 state=0;
    x-zs=clean
    (MX Record found);
    (MX Record found);
    smtp.bits=128/128;
    x-zs=clean
    xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT03
    MzU2JmNvZGU9YldGMWNtVmxiaTVvWVhKeWFYTkFkR1YwY21GMFpXTm9MbU52Ylh3M016VT
    JmRGt6T0RFME9URTJOUT09
    X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduuddrudefgddugedvucetufdoteggodetrfdotf
    fvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgfnhhsuhgsshgtrhhisggvpdfu
    rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucenucfjughrpefhvffuth
    ffkfhfjghitgggsegrtddtredttddvnecuhfhrohhmpedfjfgrrhhrihhspdcuofgruhhr
    vggvnhdfuceoofgruhhrvggvnhdrjfgrrhhrihhssehtvghtrhgrthgvtghhrdgtohhmqe
    enucffohhmrghinhepnhgrsggslhgvrdgtohhmnecukfhppeegtddruddtjedrjeekrddu
    fedupdefkedrvddvfedrvdefuddrvdehuddpfhgvkedtmeemuggtieehmeeklegvmeekfh
    efrgemudgtvgelnecurfgrrhgrmhepihhnvghtpeegtddruddtjedrjeekrddufedupdhh
    vghloheppfetofdtfedquegjvddqohgsvgdrohhuthgsohhunhgurdhprhhothgvtghtih
    honhdrohhuthhlohhokhdrtghomhdpmhgrihhlfhhrohhmpeeoofgruhhrvggvnhdrjfgr
    rhhrihhssehtvghtrhgrthgvtghhrdgtohhmqecuuffkkgfgpeduleduhedvnecuvehluh
    hsthgvrhfuihiivgeptd
    X-ME-VSScore: 0
    X-ME-VSCategory: clean
    X-ME-ZSResult: clean
    Received-SPF: pass
    (tetratech.com: Sender is authorized to use ‘[email protected]’ in ‘mfrom’ identity (mechanism ‘include:spf.protection.outlook.com’ matched))
    identity=mailfrom;
    client-ip=40.107.78.131
    Received: from NAM03-BY2-obe.outbound.protection.outlook.com (mail-eopbgr780131.outbound.protection.outlook.com [40.107.78.131])
    (using TLSv1.2 with cipher ECDHE-RSA-AES128-SHA (128/128 bits))
    for ; Mon, 8 Apr 2019 15:40:24 -0400 (EDT)
    DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=tetratech.com;
    s=selector1;
    h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck;
    b=e6svUf9ncC1vME2uUSxrb3tn2kxfXsIkqkmSnPK6ciHfsTDNjFcxhS52tu6A28o3DY6IEcB3aWMvZpOnDTJgBjoamdUk/nZBkhtzejPGP4TCcEseIcMauNAN3h9paQGAb+Lt4qDaGoUkWcDOWoBeSJRrq50OI+vU4TR/9Ty07l0=
    Received: from SN6PR07MB4701.namprd07.prod.outlook.com (52.135.77.16) by
    SN6PR07MB4591.namprd07.prod.outlook.com (52.135.75.159) with Microsoft SMTP
    Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id
    15.20.1771.16; Mon, 8 Apr 2019 19:40:20 +0000
    ([fe80::dc65:89e:8f3a:1ce9]) by SN6PR07MB4701.namprd07.prod.outlook.com
    ([fe80::dc65:89e:8f3a:1ce9%2]) with mapi id 15.20.1771.021; Mon, 8 Apr 2019
    19:40:20 +0000
    Subject: RE: Connecting 2D flow area and 1D reach
    Thread-Topic: Connecting 2D flow area and 1D reach
    Thread-Index:
    AQHU6KVSCWZnpMahLkCKn2regvLD0aYnfy8AgAAgHoCAAAkogIADUGaAgAEBQoCAAE9TAIADqasAgAAjyACAAp2RwA==
    Date: Mon, 8 Apr 2019 19:40:19 +0000
    Message-ID:
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    authentication-results: spf=none (sender IP is )
    [email protected];
    x-originating-ip: [38.223.231.251]
    x-ms-publictraffictype: Email
    x-ms-office365-filtering-correlation-id: 244c7cb7-43c2-4a3e-f079-08d6bc5a08c9
    x-ms-office365-filtering-ht: Tenant
    x-microsoft-antispam:
    BCL:0;PCL:0;RULEID:(2390118)(7020095)(4652040)(8989299)(5600139)(711020)(4605104)(4618075)(4534185)(4627221)(201703031133081)(201702281549075)(8990200)(2017052603328)(7193020);SRVR:SN6PR07MB4591;
    x-ms-traffictypediagnostic: SN6PR07MB4591:
    x-ms-exchange-purlcount: 5
    x-tt-fromtti: TtTTITenantOutgoingMail
    x-microsoft-antispam-prvs:
    x-forefront-prvs: 0001227049
    x-forefront-antispam-report:
    SFV:NSPM;SFS:(10019020)(39860400002)(346002)(376002)(396003)(366004)(136003)(199004)(189003)(2906002)(21615005)(7696005)(25786009)(11346002)(97736004)(476003)(81166006)(81156014)(966005)(256004)(316002)(72206003)(486006)(26005)(186003)(8676002)(86362001)(446003)(478600001)(71200400001)(14454004)(4744005)(8936002)(136015008)(99286004)(606006)(71190400001)(102836004)(6506007)(93886005)(66066001)(6116002)(53546011)(76176011)(790700001)(6436002)(5660300002)(3846002)(52536014)(6246003)(229853002)(7736002)(7066003)(33656002)(68736007)(236005)(105586002)(74316002)(53936002)(9686003)(10126004)(6306002)(54896002)(106356001)(55016002);DIR:OUT;SFP:1102;SCL:1;SRVR:SN6PR07MB4591;H:SN6PR07MB4701.namprd07.prod.outlook.com;FPR:;SPF:None;LANG:en;PTR:InfoNoRecords;A:1;MX:1;
    received-spf: None (protection.outlook.com: tetratech.com does not designate
    permitted sender hosts)
    x-ms-exchange-senderadcheck: 1
    x-microsoft-antispam-message-info:
    YBsYSjtwkqBDdArfd/K0lzp17jYn1hMLK0dUaKwzrIC+1zKTDNqrg4kf+kRd5LFXfATEZlyacHZb6GcP3sSmaOpuYW0KvN77o8nAAB+gRkOOy5mVqZ5NjycBPUGa394AoOjRJIZDnzYBq6ZQHoRmYZEs/4/RyZZFRUnhhMSwvFuwrANxIoB85ak5smkaRRarP8DZvHAM6uQ08eDxoIWIhY0rsKMUw9O6FjFrn8sKamW91VxeGPukBD9XcP/Xc/GiejUQD3hunuLM5HRAlOrVVjQ5wYaQoeuWlPp5/P2PWTfu5eR61CkXL5yM/FxroPkYZGCSA4Yi1VED1wnEFcOVwYEX4E8zntfHHnAaWfjRogx7JFhcbXoGF557puh703sLl/uvfeywKD4LkDBBeM6ciCR4JAJCNLR/EM4W20TIyZI=
    boundary=”_000_SN6PR07MB4701A3A452CCE018BA1A6884812C0SN6PR07MB4701namp_”
    MIME-Version: 1.0
    X-OriginatorOrg: tetratech.com
    X-MS-Exchange-CrossTenant-Network-Message-Id: 244c7cb7-43c2-4a3e-f079-08d6bc5a08c9
    X-MS-Exchange-CrossTenant-originalarrivaltime: 08 Apr 2019 19:40:19.9043
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Hosted
    X-MS-Exchange-CrossTenant-id: a40fe4ba-abc7-48fe-8792-b43889936400
    X-MS-Exchange-CrossTenant-mailboxtype: HOSTED
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: SN6PR07MB4591
    –_000_SN6PR07MB4701A3A452CCE018BA1A6884812C0SN6PR07MB4701namp_
    Sure! Which email should I use?
    Sent: Saturday, April 6, 2019 11:44 PM
    To: Harris, Maureen
    Subject: Re: Connecting 2D flow area and 1D reach
    Looks like some instabilities. If you sent me the model I could play with i=
    t.
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Connecting-2D-flow-area-and-1D-re=
    ach-tp7356p7378.html
    To unsubscribe from Connecting 2D flow area and 1D reach, click here.
    .naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-na=
    bble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nab=
    ble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21=
    nabble%3Aemail.naml>
    [email protected]>
    To: Harris, Maureen <[email protected]>
    Looks like some insta=
    If you reply to this email, your mes=
    sage will be added to the discussion below:
    http:/=
    /hec-ras-help.1091112.n5.nabble.com/Connecting-2D-flow-area-and-1D-reach-tp=
    7356p7378.html
    To unsubsc=
    click here
    NAML
    –_000_SN6PR07MB4701A3A452CCE018BA1A6884812C0SN6PR07MB4701namp_–
