Welcome to the RAS Solution › Forums › HEC-RAS Help › computational level output
- This topic has 2 replies, 451 voices, and was last updated 11 years, 1 month ago by simone minesso.
January 27, 2015 at 2:54 pm #5680simone minessoParticipant
Hi everybody,
I’m performing an unsteady flow calculation about the motion of a dambreak wave in a channel.
The channel is very short, just 4 meters long and at the end of it there’s reflection condition (closed section).
I’ve ran the simulation with the smallest time (1minute) I can choose from the “hydrograph output interval” option, but it was too long to get the wave dynamic. So as it written in the manual I have marked the “computational level output” label, that it refers to a computational time of 1sec.
After the simulation is ran by selecting the “unsteady flow spatial plot” or the “unsteady flow time series plot” options from the view menu of the main hec window, I should get all the data I need, but these two options remain gray-out. In the manual I didn’t find any explanation about it.
What problem could be and how can I solve it?thanks in advance
January 27, 2015 at 7:59 pm #9084AnonymousGuestPerhaps the ouput is not turned on for the sections of interest. This is done at the Unsteady Flow Analysis window – Stage and Flow Output Location. I think that the default here is no output and the computational level output uses this to prepare the detailed info. So, the sections for output need to be selected first.
January 27, 2015 at 8:41 pm #9085simone minessoParticipantReturn-Path:
Received: from mail-lb0-f177.google.com (mail-lb0-f177.google.com [209.85.217.177])
by mbob.nabble.com (Postfix) with ESMTP id 27E3C801291
for; Tue, 27 Jan 2015 08:37:12 -0800 (PST)
Received: by mail-lb0-f177.google.com with SMTP id p9so14069690lbv.8
for; Tue, 27 Jan 2015 08:41:35 -0800 (PST)
d=gmail.com; s=20120113;
h=mime-version:in-reply-to:references:date:message-id:subject:from:to
:content-type;
bh=nwns4frtpb1ccfrCEQm7dhOjVPI2h6+9rXYMAKftlhE=;
b=CYN1F491fMP/VYLkhS8fQYuthkWWFLdr87B6DBuMEnO376XtBZtzFpj14aJJ7egD2Z
f1oBwrJRO2lqmQwMgcdSp4/1XbVt8WYsnYzPr5STLr1mTsDah/DG3ThSn/pnWJG9nOk9
HGrX9r0Ls9R+0BmKl6gOmkO3RgZmkPmlGKV64t4VEnXXFdPGKjEbCMjqf3crVjTsSh1k
hlIIW+U/re2Y59wLgeqq6CwOAd8Ai5cHz6AncS9b75DQ8hvX5fbfCVxO78L/FxS6GkIP
YMFZ+/7aR4w1xpD76WYF5SKAguBWbpins/5Glo2xlPy8/oTKwD8IAQQxzkgL7pZs1Mz9
p7yQ==
MIME-Version: 1.0
X-Received: by 10.152.43.49 with SMTP id t17mr2966874lal.52.1422376895462;
Received: by 10.112.13.66 with HTTP; Tue, 27 Jan 2015 08:41:35 -0800 (PST)
<[email protected]>
Date: Tue, 27 Jan 2015 17:41:35 +0100
Message-ID:
Subject: Re: computational level output
To: “MichaelG [via HEC-RAS Help]”
Content-Type: multipart/alternative; boundary=001a11c23c8e9742fc050da4edea–001a11c23c8e9742fc050da4edea
Content-Transfer-Encoding: quoted-printableUnfortunately it’s not about that problem. I have alredy chosen and set the
stage and flow output location.2015-01-27 16:59 GMT+01:00 MichaelG [via HEC-RAS Help] < [email protected]>:
> done at the Unsteady Flow Analysis window – Stage and Flow Output Locatio=
n.
> output uses this to prepare the detailed info. So, the sections for outpu=
t
> below:
> http://hec-ras-help.1091112.n5.nabble.com/computational-level-output-tp12=
49p1252.html
> To unsubscribe from computational level output, click here
=3Dunsubscribe_by_code&node=3D1249&code=3Dc2ltb25lLm1pbmVzc29AZ21haWwuY29tf=
DEyNDl8LTMwMjY1MDQy>
> NAML
ace-nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNa=
mespace-nabble.view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscri=
bers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instan=
t_email%21nabble%3Aemail.naml>
Content-Transfer-Encoding: quoted-printableUnfortunately it's not about that problem. I have alre=
dy chosen and set the stage and flow output location.2015-01-27 16:59 GMT+01:00 Michae=
lG [via HEC-RAS Help] <[email protected]=
bble.com>:in:0 0 0 .8ex;border-left:1px #ccc solid;padding-left:1ex">
Perhaps the ouput is not turned on for the sections of interest. This is d=
one at the Unsteady Flow Analysis window – Stage and Flow Output Location. =
I think that the default here is no output and the computational level outp=
ut uses this to prepare the detailed info. So, the sections for output need=
to be selected first.=09
=09
=09
will be added to the discussion below:http://hec-ras-help.1091112.n5.n=
abble.com/computational-level-output-tp1249p1252.html–001a11c23c8e9742fc050da4edea–
