Welcome to the RAS Solution Forums HEC-RAS Help Combine two reaches
  • #5882
    marie_eve
    Hi !
    Is there a way to combine two reaches to keep the XS and bridges and inlines that are in. Actually I have two reaches for no reasons (no junctions, no input, etc.); I would like to only have one reach with all my river.
    I know it’s seem simple. But I can’t find anything.
    Thanks.
    #9501
    I’m not sure how you end up with two reaches with no junction between them. The usual way to combine two reaches is by deleting the junction.
    When you are trying to separate or combine things in a RAS geometry, it is sometimes easiest to make a copy of the geometric data (using the “save as” feature) and then use the import geometry data that is available under Geometry editor/File. You can selectively import reaches/cross sections/bridges etc. from the original geometry file.
    #9502
    Keymaster
