Welcome to the RAS Solution Forums HEC-RAS Help Channel Design/Modification Editor functionality
  • #5313
    Bob Davies
    I am using the Channel Design/Modification routine. I have two main issue questions.
    1) I have defined and input the templates I desire. As I select the templates to be specified for the cross-sections I have realized after the fact that I wanted to leave several of the section in a natural or existing conditions state. How can I unspecify a template and therefore have no template to be modified for the sections I choose?? I have not yet created a new geometry file yet and I dont want to have to start over specifying my templates. Editor does not seem to allow me to apply “no template” to a few sections I have already inadvertantly applied a template to. Can I edit a file in text editior to accomplish this?
    2) As I was going through the same project specifying templates for modification, I realized I needed to delete a cross-section which was in error So I exited the Channel Mod editor. went into geometric data editor and deleted the cross-section. However, when I came back to channel modification editor the deleted section is still there. How do I delete it from the channel modification editor???
    Thank you for any help you can provide. Trying to minimize my rework!!
    Bob
    #8470
    Keymaster
    I think you are on the right track with editting the geometry file directly. Definately save a copy first, then make your changes. It may take a little detective work to figure out what is what in the geo file.
    Good luck.
