Welcome to the RAS Solution Forums HECRAS Controller changing mannings n in 2D areas
  • This topic has 7 replies, 1,368 voices, and was last updated 9 years ago by Anonymous.
  • #8197
    I have a combined 1D/2D reach where a 1D river flows into a 2D area and flows back into a 1D reach downstream of the 2D area. I can easily modify the manning n in my 1D reaches using hec-ras controller. however, in my 2D reaches, though the manning’s table in the geometric data editor window shows that default manning’s n has been replaced, the pre-processor doesn’t run to update the hydraulic parameters of the 2D area before running the model. How do i make hec-ras update the cell properties after each run?
    #13547
    have you found any solution ?
    #13548
    Manning is only updated using the GUI, I changed manning in HDF and in geo file with no results, hecras always ignores any changes so when it runs the plan it runs it on the old manning values and ofcourse saves it again in the hdf file
    #13549
    No I haven’t been able to. The GUI is reading the new values and running the pre-processor, but the controller is not. If you can find a way, it would be much appreciated
    #13550
    I have found a solution
    #13551
    PaoloP
    Please, could you share the solution?
    #13552
    Kindly share the solution. it would be very helpful for us.
    #13553
    Change the .tiff manning file its self it will force hecras to recompute
