Welcome to the RAS Solution Forums HEC-RAS Help Cannot open project components
  • This topic has 3 replies, 1,030 voices, and was last updated 9 years ago by Anonymous.
  • #6250
    I have project that used to run properly. When I tried to open the file again, the plans are missing including the geometric files and flow files (Figure 1 Main). I also cannot see it in the list when I try, for example, “Open Geometry Data” (Figure 2). I can only see the list of geometry files included in the project when I try to “Save As” a blank geometric file (Figure 3). I put some images in the following link.
    https://drive.google.com/drive/folders/0B34MjleK7If1Vm8yNFdvd0NNZ1U?usp=sharing
    I can see the results also in the Ras Mapper but I cannot see the profile results because I cannot see and open the plans. They still however exist in the project and folder I am working at. I don’t know what happened or what went wrong since the last time I open the project file it was working fine.
    Can anybody please help me solve the problem?
    Thank you very much
    #10168
    How does the *.prj file look? Does it contain all of the plan/geometry files?
    #10169
    yes it contains all the geometry files because I can import the “should-be existing geometry file” to a new geometry file. As for the plan, I cannot see them on the dropdown list as if they do not exist; but when I try to save a new plan I can see the “should-be existing plans”.
    So what I’ve been doing so far is to import the geometry data to a new and blank geometry file. However I encountered a new problem. After importing the new geometry file and running a new plan, I did a first run and it was successful. When I tried to do it again I received an “exit error”.
    I tried to run the files in Versions 5.0.0, 5.0.1 and 5.0.3 but I still get the error. So, I’m still at a loss for now.
    #10170
    Have you tried it on a different machine?
