Welcome to the RAS Solution Forums HEC-RAS Help can storage area connected directly to XS?
  • #5640
    hillwinner
    I got the errors like below:
    Storage Area: “11a2″ has a minimum elevation specified in the geometry as -1(ft) and is connected to :”XS: RS=3.5” which has a minimum elevation of -3.17(ft)
    The storage area and XS have different minimum elevation. Do they have to be same min elevation?
    See attach screen capture for the connection to XS , instead of LS.
    Sean
    #9016
    Lonnie A
    You just need to edit the storage area’s first point to an elevation -3.17 or lower. You can set your -1 elev vol to 0.01 if you want to keep that point
