Welcome to the RAS Solution › Forums › HEC-RAS Help › Can I use a .tin from microstation and create a terrain in the mapper?
- This topic has 9 replies, 1,250 voices, and was last updated 8 years, 12 months ago by lkhoury.
April 12, 2017 at 8:20 pm #6418lkhouryParticipant
I have a .tin file that I exported all my cross sections from. I just want to use it as a terrain in the mapper. Also, I have a raster that I tried to use but it keeps switching elevations to metric or something else. My elevations should be in the 600-7-00 range but I’m getting 35-250 range. I made sure the projection is correct but I just cant get it right! here is what I am talking about.
April 14, 2017 at 6:13 pm #10501Lonnie AParticipantYou have to convert the tin to a raster prior to importing it into RAS. Not sure on the elevation issue. In the main window of RAS under options it isn’t set to metric by chance is it? I don’t believe that would be the cause, more likely a issue with the raster/projection.
April 14, 2017 at 6:45 pm #10502AnonymousGuestI checked it’s not meters. The top is extracted from microstation tin and the bottom is the terrain plot. My guess is the terrain is wrong or when I converted it, it became somehow in meters… I’ll see if microstation has a way to convert tin to raster
ThanksApril 20, 2017 at 5:10 pm #10503lkhouryParticipantI figured it out. If anyone encounters the same problem, please let me know and I will be happy to walk you through it.
April 24, 2017 at 4:15 pm #10504AnonymousGuestI was curious your method of converting your .tin into a raster format for HECRAS. I typically convert the .tin to landxml in Microstation. Than in GIS Create a TIN based upon the landxml. From there I’m able to convert to raster. Only issue i have is the grid size for the raster won’t let me change it to something with a better resolution. It defaults to a value.
April 24, 2017 at 4:51 pm #10505lkhouryParticipantThat’s exactly what I did.. I have a good surface on the project I am working with but I will keep an eye on the resolution and will let you know if I find something new. Thanks for sharing
April 24, 2017 at 5:17 pm #10506lkhouryParticipantWhen you convert from tin to raster using Arc conversion tool, there is a sampling distance (optional) in the conversion window. You can pick the sampling size there. My other guess for a low resolution of raster is that the tin itself has big intervals.
Hope that helps..November 2, 2018 at 8:46 pm #10507[email protected]Participanthi lkhoury,
I do facing same problem, I have tin file from microstation/geopak, want to make a terrain in Ras mapper, can u guide me step by step, will appreciates. I have access to QGIS.
ThanksNovember 3, 2018 at 5:35 am #10508lkhouryParticipantReturn-Path:
by sloti1d2t14 (Cyrus 3.1.5-610-gd7ceb27-fmstable-20181026v1) with LMTPA;
Fri, 02 Nov 2018 21:35:27 -0400
X-Cyrus-Session-Id: sloti1d2t14-523083-1541208927-2-2406297150773818782
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 2.5
X-Spam-hits: FREEMAIL_ENVFROM_END_DIGIT 0.25, FREEMAIL_FROM 0.001, FREEMAIL_REPLY 1,
HTML_MESSAGE 0.001, MIME_QP_LONG_LINE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
SPF_PASS -0.001, URI_HEX 1.313, LANGUAGES en, BAYES_USED none,
SA_VERSION 3.4.0
X-Spam-source: IP=’209.85.210.53′, Host=’mail-ot1-f53.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
Received: from mx1 ([10.202.2.200])
by compute1.internal (LMTPProxy); Fri, 02 Nov 2018 21:35:27 -0400
Received: from mx1.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 76AC12D0D5
for; Fri, 2 Nov 2018 21:35:26 -0400 (EDT)
by mx1.messagingengine.com (Authentication Milter) with ESMTP
id 2F5A0FFC491;
ARC-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=fm1; t=
1541208926; b=cAfoQZI5vUo3WPLEfpfYZPqLm9+q2omU1CpQu5NrXb3/QIHIVB
b7oqDi4kOtMr8EzlJMMBoVK/JMHFfq6SnERQUOAHwDlR9ItZYWSGwPrXWsiAYi4U
Xx6KnJc+gFCr3w6/nvD2j7Wlxf43PylFzvrKZQyDbAeX8o9NdprTbUr407/bPhCz
7uRud5QoynoUytqY/rULok2LH20np3VsD7OWDZdDRu9kStG+//QEmIQmktw/uHQu
NKnKt68fh3Jyo9rAkSzCI8VhbHWco5ZhX2DKKuDc/XPo76hxLrMHmwVaUWDiy+HE
yuyvjq/kgebXWvvGrlo4bzN4V6UerdtEBrMw==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm1; t=1541208926; bh=zG/FWzHgYbOD
9X6ZksFVFvOlsCgE9SW5BZa6eAMoGZg=; b=b2/Otl6QIPOQ5clh58xPyeRxM7Vx
vmBRXJt8BeEJjOLxW3bePi+mALifx9pRZdA4iHCf0lQw3dp/LopWWUAIq6S1y2HG
FzCCViiMW8ZHnwmKW4RTOmEKc/qf8mKyRFGc2qaS0AV0JVRDE5dESAamziB32kIo
L8RTYVhDOzk471nYOxAg5Usv0qBcK1iIK2F6Xz9xm2RyH1GxigLujPXPCDyCVdlf
K0e8wWROLHX+KgpYhfmj11QzD2Ci8JjdWkqF5vNhEO8sQADMThm7j/2wDI4AV9LW
WvahRDCdnLiXuHU4VyP1kUxAzYeWiCbZAQQDyE7WdZhz03J9eWETOznzRA==
ARC-Authentication-Results: i=1; mx1.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=u1JfKEab header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.210.53 (mail-ot1-f53.google.com);
spf=pass [email protected]
smtp.helo=mail-ot1-f53.google.com;
x-cm=none score=0;
[email protected] header.b=p9kGfnNL;
x-ptr=pass smtp.helo=mail-ot1-f53.google.com
policy.ptr=mail-ot1-f53.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx1.messagingengine.com;
x-cm=none score=0;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0z
ODMwJmNvZGU9YkdsdVlXdG9iM1Z5ZVRsQVoyMWhhV3d1WTI5dGZETTRNekI4TWpFeU56QT
JPVGsyTkE9PQ
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedtkedrjedtgdeflecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgenuceu
rghilhhouhhtmecufedttdenucenucfjughrpefhtgfgggffuffkfhgjvffosegrjehmre
hhtdejnecuhfhrohhmpehlihhnrghkhhhouhhrhielsehgmhgrihhlrdgtohhmnecuffho
mhgrihhnpehnrggssghlvgdrtghomhenucfkphepvddtledrkeehrddvuddtrdehfedpvd
eitddtmedujedttdemvddvugdtmeekrgeftdemfhegieehmehfgeeileemugejheehmegt
tdelleenucfrrghrrghmpehinhgvthepvddtledrkeehrddvuddtrdehfedphhgvlhhope
hmrghilhdqohhtuddqfhehfedrghhoohhglhgvrdgtohhmpdhmrghilhhfrhhomhepoehl
ihhnrghkhhhouhhrhielsehgmhgrihhlrdgtohhmqecuuffkkgfgpeeijedujeenucevlh
hushhtvghrufhiiigvpedt
X-ME-VSCategory: clean
X-CM-Envelope: MS4wfJdvpqPS8q3rc3T8NhMwmLBFqaTtt56FH7GsfGH1sfaj1XfnlEHzejwYUr1VaqzOctPcWaows5LZ3Ih4kuYphUSE1+kzLp+LIfdJiqQX25JnMXcrI/u9
DsvmVcPsYQopp0cwyTqBl2WHHW2OoDqCrAS2ruBZZ+JFmTvzRcwT3XnUs3/8bV3kuqv8cm0kQtKL6rvY0u4ST1CtkdZE+sCEZhLnekWVwVLcdn2wmEiEZaVk
X-CM-Analysis: v=2.3 cv=J8d7EzvS c=1 sm=1 tr=0 a=YKy5iuLXnxoOKB4xgfqhSw==:117
a=x7bEGLp0ZPQA:10 a=ior0A6s6_BgA:10 a=xqWC_Br6kY4A:10 a=4_-BN3WEXhEA:10
a=JHtHm7312UAA:10 a=69EAbJreAAAA:8 a=9I5xiGouAAAA:8 a=iKhX2YneFEho2etbB-AA:9
a=QEXdDO2ut3YA:10 a=vhxSUSY-IuUA:10 a=zLmChLUpyZnWDgiA:21 a=_W_S_7VecoQA:10
a=ARFN2YZ7Uv8kHtb7LS-q:22
X-ME-CMScore: 0
X-ME-CMCategory: none
Received-SPF: pass
receiver=mx1.messagingengine.com;
identity=mailfrom;
client-ip=209.85.210.53
Received: from mail-ot1-f53.google.com (mail-ot1-f53.google.com [209.85.210.53])
by mx1.messagingengine.com (Postfix) with ESMTPS
for; Fri, 2 Nov 2018 21:35:25 -0400 (EDT)
Received: by mail-ot1-f53.google.com with SMTP id g10so3256113otl.12
for; Fri, 02 Nov 2018 18:35:25 -0700 (PDT)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=zG/FWzHgYbOD9X6ZksFVFvOlsCgE9SW5BZa6eAMoGZg=;
b=u1JfKEabMHhv+7HF/Juck0omJ39wx3FUlLTUi3o0uuJ24roUtdEiOw0geBlaU5pyng
vYmAnFO1WRrfKi9KcrXHGRpnAeOEdK/WhtIHwlmznU3N1zdmOShYpBRXYIEIjSBnO0Rg
qxdvSSB2Tnbkb+rZBjuWkaEeh1Y13hhybtXNWKXR3OLH+6HFBXs92V+d1DWYWhL3zRSQ
1aRfYjXkQTr4Wy1NttluUv/9YLxjcQF0yL3AwJbVcHz/q/Ul34a8w4JqKM4PCqvhlmSP
Q5ykLGRbnJWlG2p95kng2K2RKES4KZS+y8u5zD36yMm2SWlyNbOATAyubVxCjkb81dq1
CulQ==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=p9kGfnNLExgk9GkUillEB/ObuOSyr+tdg3tYFzK9+NvmeusCF/Z/ECxwoL65UcC6P5
AnVAjta0EoTgZ6OGNtdt4XcNchwbSDyz1hsSEoHV4utbMvitHQ0DaKLxowMKXHluCtHD
8V5v0Qp0BHDXk4feR/gTT0C0hgC6jBUky7u4/Uzr7kLGTAJiNkfi2chGjVV9N3iN1Bsg
VnJpoSynLebtycyAH/1YxDyviIFqd2iSuiwFtSdI1L0qwhzGkgAperQA9SMl4zb6yEvl
rtR/uZyInNqkiituCNgimeoEEI1fmaGglBcKl2odY7i5FWYi0ioHH4d3fgmteIPZqBqg
mlfg==
X-Gm-Message-State: AGRZ1gI1yoeDlEcWPtNouuUPONH/kLgYypWkMzDPvIDd8ivpLc61FR2q
dTU0OsmQqQ8DSgnteDCWeZbGMKi/
X-Google-Smtp-Source: AJdET5f51O8vRW1GgBnL59MgiPinsM0aoyYWkOOuYA6SEoeCst51Tmv0FV+phUvESoUung0m9xPtZA==
X-Received: by 2002:a9d:3ecb:: with SMTP id b69mr2693728otc.329.1541208924089;
Fri, 02 Nov 2018 18:35:24 -0700 (PDT)
Received: from ?IPv6:2600:1700:22d0:8a30:f465:f469:d755:c099? ([2600:1700:22d0:8a30:f465:f469:d755:c099])
by smtp.gmail.com with ESMTPSA id h25sm3968703otm.56.2018.11.02.18.35.22
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Fri, 02 Nov 2018 18:35:22 -0700 (PDT)
boundary=Apple-Mail-D9BAA0EA-BD07-4E6D-87CC-7F1B67351A8B
Mime-Version: 1.0 (1.0)
Date: Fri, 2 Nov 2018 20:35:21 -0500
Subject: Re: Can I use a .tin from microstation and create a terrain in the mapper?
References: <[email protected]> <[email protected]> <[email protected]> <[email protected]> <[email protected]>
To: “[email protected] [via HEC-RAS Help]”
X-Mailer: iPhone Mail (15G77)–Apple-Mail-D9BAA0EA-BD07-4E6D-87CC-7F1B67351A8B
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printableHi!=20
The method I know requires 3D analyst tool. If you don=E2=80=99t have licens=
e for that then I=E2=80=99m afraid I can=E2=80=99t help you.
Good luck!=20Sent from my iPhone
> On Nov 2, 2018, at 11:46 AM, [email protected] [via HEC-RAS Help]
wrote:
>=20
> hi lkhoury,=20
>=20
> I do facing same problem, I have tin file from microstation/geopak, want t=
o make a terrain in Ras mapper, can u guide me step by step, will appreciate=
s. I have access to QGIS.=20
> Thanks=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Can-I-use-a-tin-from-microstatio=
n-and-create-a-terrain-in-the-mapper-tp3830p6615.html
> To unsubscribe from Can I use a .tin from microstation and create a terrai=
n in the mapper?, click here.
> NAML–Apple-Mail-D9BAA0EA-BD07-4E6D-87CC-7F1B67351A8B
Hi!
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: quoted-printableThe method I know requires 3D=
analyst tool. If you don=E2=80=99t have license for that then I=E2=80=99m a=
fraid I can=E2=80=99t help you.Good luck!Sent from my iPhone On Nov 2, 2018=
, at 11:46 AM, ibrahim_004@hotmai=
l.com [via HEC-RAS Help] <[email protected]> wrote:hi lkhoury,
I do facing same problem, I have tin file from microstation/geopak, w=
ant to make a terrain in Ras mapper, can u guide me step by step, will appre=
ciates. I have access to QGIS.=20
Thanks=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:
=09
To unsubscribe from Can I use a .tin from microstation and c=
reate a terrain in the mapper?, click=
here.
NAML=
–Apple-Mail-D9BAA0EA-BD07-4E6D-87CC-7F1B67351A8B–
November 6, 2018 at 12:55 am #10509[email protected]ParticipantThanks
