Welcome to the RAS Solution Forums HEC-RAS Help Can I change the flow direction of a reach?
  • #5416
    Marulke
    I have the following problem:
    Two rivers, A and B, run parallel some hundred meters apart. The water in the two rivers both flow in the same direction. A canal, perpendicular to the rivers, connect them. Flow direction in the canal is defined to be from A to B, (based on how I drew the system on the schematic).
    Actual flow in the canal may be from river A to B, or from B to A, depending on the flow / water level in the two rivers.
    However, it seems that HEC is only able to calculate flow in one direction in the canal. When flow is from A to B, everything is OK, also flow split optimization works.
    When flow in the canal is from B to A, the flow split optimization does not find a solution. When I do the flow split manually, by defining a negative flow in the canal (from B to A), HEC sets the canal flow to zero.
    Questions
    Is there an easy way to change the definition of the flow direction of a river reach.
    Does HEC handle negative flow (flow in opposite direction) for steady flow calculations
    #8660
    Keymaster
    RAS cannot handle negative (upstream) flow in steady flow. Good news is you can run unsteady flow and have flow in both directions for a given reach.
    #8661
    Marulke
    Thanks Chris, I will try running the model with unsteady flow.
