Welcome to the RAS Solution Forums HEC-RAS Help Calculating reach length
  • #5533
    Hi
    I created cross sections at a distance of 50 meters one from the other, but due to curves in the reach, this distance is not constant for the LOB and ROB.
    I’ld prefer not to measure it by hand, but rather have the software calculating it – is that possible?
    #8835
    You can do it automatically using HEC-GeoRAS and ArcGIS. By the way, we do HECRAS courses in Europe, and if you can get together 5 or more attendees it can be quite affordable. I just got done teaching a RAS class in Sweden. Let me know if you would like more information about this.
    [email protected]
    #8836
    I use QGIS and not ArcGIS. Are you familiar with that software?
    Will contact you privately about courses.
    #8837
    Also, is there a way to import bank stations (as csv for example) or do I need to define them per cross section?
