Welcome to the RAS Solution Forums HEC-RAS Help Calculating length between cross sections in an automatic way?
  • #5354
    Pallo
    Hello
    I’m afraid I don’t have a good english, sorry.
    I have in HEC-RAS the cross sections, but unfortunately I don’t have the lengths between cross sections. They are georeferenced, then I wonder if I can give the length automatically.
    #8550
    Keymaster
    Digitizing flow lines in ArcGIS will allow HEC-GeoRAS to automatically calculate reach lengths for you. They will come into RAS when you import your GIS import file. If you don’t have access to GeoRAS, then I’m afraid you have to enter in the reach lengths manually.
    Good luck.
    @RASModel
    #8551
    Pallo
    Thank you for your answer.
    Then I have to enter the reach lenghts manually, because I don’t work with ArcGIS in this project.
    #8552
    jadams
    Create a dummy cross section manually at any station. You do not have to populate the values just make it. Then immediately delete it. The program will ask if you want to update reach lengths.
    #8553
    Pallo
    Thank jadams for your message
    I think, that works when you have already reach lengths, but I don’t have any reach lengths.
