Welcome to the RAS Solution › Forums › HEC-RAS Help › calculating just a cross-section capacity
  • #5638
    Hfarhadi
    Hi everyone
    How can I just calculate flow discharge capacity in a cross-section of a channel?
    (which it’s known that HecRAS uses DCM to do it)
    #9015
    Lonnie A
    If you set up a dummy unsteady run and just execute the geoproccesor you’ll get the htab data. If you need the conveyance capacity at a certain elevation you can adjust the xs htab table so you get results at that elevation.
