Welcome to the RAS Solution Forums HEC-RAS Help calculated depth reachs
  • This topic has 0 replies, 34 voices, and was last updated 6 years ago by sam1.
  • #7477
    sam1
    The calculated flow reachs downstream and then starts again from upstream:
    I have a hydrographic flow as a boundary condition upstream and a normal depth for the downstream. Once the calculation is completed and the results are displayed: the water starts from the upstream limit, reaches the downstream and then disappears completely to start again from the upstream and the loop continues.
