Welcome to the RAS Solution Forums HEC-RAS Help bug or error in sediment analysis with version 5.0?
  • This topic has 0 replies, 112 voices, and was last updated 10 years ago by Anonymous.
  • #5905
    I try to model sediment transport upstream a dam. I use USI units and the version 5.0. I use a diameter of 25 mm for sediments (class between 24 and 26 mm) . However, when I look at the results, some 3.048 10^(-8) mm diameters appear.
    Has somebody already had this problem before ?
    Is it a bug or just a bad choice for parameters ?
    Thanks in advance
    Regards
    CIH 2
