• This topic has 8 replies, 1,695 voices, and was last updated 9 years ago by Anonymous.
Viewing 9 posts - 1 through 9 (of 9 total)
  • #6213
    I have a long reach in which we wish to model the channel and overbanks with 2D. However, there are several bridges which do not cross the floodplain so I am trying to figure out the best approach to model the bridges.
    My approach has been to model with 2D and then run short 1D reaches through the bridges and then return to 1D. I am running into a mismatch at the 1D/2D interfaces (where flow enters or exits the 1D reach at a cross section). This is especially prevalent at the downstream 1D section. What I am experiencing is a sudden drop in velocity and a sharp rise in WSE.
    I am wondering if anyone has experience with a similar situation and if there are any tips and tricks out there for how to handle bridges in the 2D environment.
    Thanks!
    #10091
    If you haven’t already done so, go into the Options menu and turn on 1D/2D iterations.
    If the water doesn’t hit the bridge deck, you might try leaving the actual bridge out and modeling with 2D by adding the abutment to the terrain. If you use really small cells, you can also add any piers to the terrain. This has to be done outside of RAS.
    You might be able to model the bridge by using a storage area connector and using culvert to represent the bridge opening.
    #10092
    Ian Sharp
    Thanks for the response Jarvus. I have used the 1d/2d iterations and have found no improvement. The image shows a typical example of what I am finding where the velocity at the downstream interface is zero in the 2D section.
    #10093
    Maybe try adding more cells at the 1d/2d boundary. As a rule of thumb you don’t want cells to change in size by more than 50% from one to the other, so try small regular shapped cells by the transition and a gradient in size from there. Also could it be from a change in Mannings?
    #10094
    Ian Sharp
    Thanks Toby. I have tried to add more cells and have also adjusted the roughness values to better match, but the problem remains. I am wondering if there might be a problem that is occurring because I am only modeling the channel in 1D and not the entire floodplain (I am modeling 2D over the bridge approaches).
    #10095
    Maybe look at this:
    http://hecrasmodel.blogspot.de/2016/05/bridges-in-2d-important-update.html
    Combining 1D and 2D for modeling bridges in 2D areas was not considered. If you find out a good way, please share with us.
    #10096
    Ian Sharp
    Return-Path:
    Received: from NAM02-BL2-obe.outbound.protection.outlook.com (mail-bl2nam02on0090.outbound.protection.outlook.com [104.47.38.90])
    by mbob.nabble.com (Postfix) with ESMTP id 29BC832E7533
    for ; Wed, 5 Oct 2016 05:29:59 -0700 (PDT)
    d=jefuller.onmicrosoft.com; s=selector1-jefuller-com;
    h=From:Date:Subject:Message-ID:Content-Type:MIME-Version;
    bh=5VvYzv7cj6FlLq8s1ES1ub9pNkc9dOObOsxtz/swMqo=;
    b=d98OakVG55jHSiaaUlf34XykM+Hea6baWVixD4PR2hAeqtyeOBg9euqcR8Lvrg6V83wDd8RXBgZXeqXWpecdWMsYaqHpNITeOhpBqmBZ3i9VAY6gY1ZDZYlSne8pHQ3nEvxvJ+2/DCPpoPEf0Bprg93UV6eKA+dSmLNlM/sO9U4=
    Received: from DM2PR0401MB0974.namprd04.prod.outlook.com (10.160.98.14) by
    DM2PR0401MB0973.namprd04.prod.outlook.com (10.160.98.139) with Microsoft SMTP
    Server (version=TLS1_2, cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384_P384) id
    15.1.649.16; Wed, 5 Oct 2016 12:34:47 +0000
    Received: from DM2PR0401MB0974.namprd04.prod.outlook.com ([10.160.98.14]) by
    DM2PR0401MB0974.namprd04.prod.outlook.com ([10.160.98.14]) with mapi id
    15.01.0649.021; Wed, 5 Oct 2016 12:34:47 +0000
    To: “guana [via HEC-RAS Help]”
    Subject: Re: Bridges in 2D
    Thread-Topic: Bridges in 2D
    Thread-Index: AQHSGdRqGnQdp7HLs0GiFwK64KbHxqCPdy8AgAALHwCAAA+RgIAKKxsAgAAZE/E=
    Date: Wed, 5 Oct 2016 12:34:46 +0000
    Message-ID:
    <[email protected]>
    <[email protected]>
    <[email protected]>
    <[email protected]>,<[email protected]>
    Accept-Language: en-US
    Content-Language: en-US
    X-MS-Has-Attach:
    X-MS-TNEF-Correlator:
    authentication-results: spf=none (sender IP is )
    [email protected];
    x-originating-ip: [132.245.15.229]
    x-ms-office365-filtering-correlation-id: d7dd83f3-c56a-4412-da67-08d3ed1bfe19
    x-microsoft-exchange-diagnostics: 1;DM2PR0401MB0973;7:b51e0rFfwfebId7mD7issy8lSZoS57O6uvJ/tqCcqeWZhCKlVGO5lnBDvs1CGtLLG+f9QzAfEX9Bw7ekU58C3lvRZdEaGLlQRu7anXMgymFmy8p0tHOiCQh51Oc80Nlfb8I1XTLGlIOQd+EBsd5uoRevzWtH2j8b+ovavUtNsDZnnxowlCdefOtwAH/k4ZU7Jo+r0xX6Qosuj1HTPVnLSEiCPCfqgK6cai0S2ESGJi0JPxg9P+F6DwlC1D6lWbNVoBwvPNGKYj2Kv9lzgIzEz2n5DOuzFGNwI/r5LLQsB8v4Tk4ogGg+dvMCAPY12eui2k0vNov8GJFAPeirFpmfrg==
    x-microsoft-antispam: UriScan:;BCL:0;PCL:0;RULEID:;SRVR:DM2PR0401MB0973;
    x-microsoft-antispam-prvs:
    x-exchange-antispam-report-test: UriScan:;
    x-exchange-antispam-report-cfa-test: BCL:0;PCL:0;RULEID:(6040176)(601004)(2401047)(8121501046)(5005006)(3002001)(10201501046)(6042046)(6043046);SRVR:DM2PR0401MB0973;BCL:0;PCL:0;RULEID:;SRVR:DM2PR0401MB0973;
    x-forefront-prvs: 008663486A
    x-forefront-antispam-report: SFV:NSPM;SFS:(10019020)(7916002)(377454003)(189002)(199003)(97736004)(87936001)(122556002)(92566002)(7696004)(107886002)(81156014)(81166006)(8676002)(189998001)(54356999)(50986999)(76176999)(5660300001)(106356001)(106116001)(3660700001)(3280700002)(7066003)(105586002)(110136003)(99286002)(9686002)(68736007)(14971765001)(3846002)(19580395003)(101416001)(19580405001)(8936002)(2950100002)(10400500002)(6116002)(10126002)(76576001)(66066001)(19617315012)(74316002)(7906003)(450100001)(15975445007)(33656002)(5002640100001)(7846002)(86362001)(102836003)(2900100001)(2906002)(11100500001)(93886004)(77096005)(7736002)(586003)(16236675004);DIR:OUT;SFP:1102;SCL:1;SRVR:DM2PR0401MB0973;H:DM2PR0401MB0974.namprd04.prod.outlook.com;FPR:;SPF:None;PTR:InfoNoRecords;MX:1;A:1;LANG:en;
    received-spf: None (protection.outlook.com: jefuller.com does not designate
    permitted sender hosts)
    spamdiagnosticoutput: 1:99
    spamdiagnosticmetadata: NSPM
    boundary=”_000_DM2PR0401MB0974F04DEB82760BBB4913DED8C40DM2PR0401MB0974_”
    MIME-Version: 1.0
    X-OriginatorOrg: jefuller.com
    X-MS-Exchange-CrossTenant-originalarrivaltime: 05 Oct 2016 12:34:46.9186
    (UTC)
    X-MS-Exchange-CrossTenant-fromentityheader: Hosted
    X-MS-Exchange-CrossTenant-id: c4c4bde8-81fb-4d0b-ba7a-b1dd9df31d6d
    X-MS-Exchange-Transport-CrossTenantHeadersStamped: DM2PR0401MB0973
    –_000_DM2PR0401MB0974F04DEB82760BBB4913DED8C40DM2PR0401MB0974_
    Will do. Thanks!
    Ian Sharp, P.E., CFM
    Project Manager/Engineer | JE Fuller/Hydrology & Geomorphology
    Direct Line: 520-207-0008| [email protected]
    Tucson Office: 520-623-3112 |www.jefuller.com<http://|www.jefuller.com>
    Sent: Wednesday, October 5, 2016 4:05:02 AM
    To: Ian Sharp
    Maybe look at this:
    Combining 1D and 2D for modeling bridges in 2D areas was not considered. If=
    low:
    http://hec-ras-help.1091112.n5.nabble.com/Bridges-in-2D-tp3079p3116.html
    To unsubscribe from Bridges in 2D, click here<http://hec-ras-help.1091112.n=
    5.nabble.com/template/NamlServlet.jtp?macro=3Dunsubscribe_by_code&node=3D30=
    79&code=3DaWFuQGplZnVsbGVyLmNvbXwzMDc5fC05Nzk1ODg3Mjg=3D>.
    .view.web.template.NodeNamespace&breadcrumbs=3Dnotify_subscribers%21nabble%=
    3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabb=
    le%3Aemail.naml>
    Will do.  Thanks!
    Tucson Office: 520-623-3112 |www.jeful=
    ler.com
    lp] <ml-node+[email protected]>
    To: Ian Sharp
    Maybe look at this:
    http://hecrasmodel.blogspot.de=
    If you reply to this email, your message wi=
    ll be added to the discussion below:
    http://hec-ras-help.1091112.n5.nabble.com/Bridges-in-2D-tp3079p31=
    16.html
    click here
    M. L. Harris
    I’m experiencing a similar problem. Were you able to find a resolution?
    #10098
    I have the same problem with bridges in a combined 1D2D model. My bridges work fine in pure 1D and I only added a 2D flow area with a lateral structure upstream of the bridge…
