Welcome to the RAS Solution Forums HEC-RAS Help Bridge openings
  • #5951
    Mary Lee
    Hi Chris,
    I have a bridge like below. RAS failed and complained that
    the road/weir is lower than the bottom of the bridge opening.
    The program cannot solve for a [single opening] bridge answer that
    does not have flow in the bridge opening. Try modeling
    the opening as a multiple opening with a bridge and a conveyance area.
    Error Accepting the preprocessor files.
    What should I do? Thank you.
    Mary.
    #9580
    mikedwyer
    Does the “Min Weir Flow El:” in the Deck/roadway Data Editor have anything in it? I normally leave this blank and let HEC RAS use the default.
    #9581
    I just had this happen as well on a Floodway model. I found that the left and right encroachment stations were both inadvertently set to the left of the bridge. This kept the bridge from receiving any water. When I fixed my encroachments the model worked.
