Welcome to the RAS Solution Forums HEC-RAS Help BRIDGE IS ACTING LIKE DAM IN HEC RAS6.0 2D MODEL
  • #7851
    KARTIK MOHAN KANSAL
    HELLO,
    I AM PREPAIRING A 2D MODEL IN HEC RAS, AND WHEN I AM PLACING THE BRIDGE IT IS ACTING LIKE DAM . AFTER STIMULATION WATER IS NOT FLOWING FROM BRIDGE, BRIDGE IS STOPPING WATER LIKE A DAM IT DOES NOT ALLOW WATER TO FLOW.
    I HAVE PLACED BRIDGE IN 2D MODEL FROM SA/2D CONNECTIONS AND ENTER ALL THE DATA WHICHI IS NEED FOR A BRIDGE.
    PLEASE KINDLY HELP ME OUT AND GIVE THE SOLUTION REGARDING THIS PROBLEM, SO I CAN KNOW WHY THIS PROBLEM IS OCCURING.
    THANK YOU
    #13007
    Luis Partida
    Check your internal bridge cross sections.
    #13008
    KARTIK MOHAN KANSAL
    still not working
    #13009
    Luis Partida
    Add pics of the structure editor as well as the geometry data editor with the terrain showing
    #13010
    Ian Sharp
    You may be having the same issue I identified in another thread. If the terrain does not include the channel through the bridge, then RAS will treat it as a dam.
    http://hec-ras-help.1091112.n5.nabble.com/Ras-6-0-Bridges-through-embankments-td9519.html
