Welcome to the RAS Solution › Forums › HEC-RAS Help › BRIDGE IS ACTING LIKE DAM
- This topic has 0 replies, 13 voices, and was last updated 5 years, 1 month ago by KARTIK MOHAN KANSAL.
February 23, 2021 at 6:27 pm #7850KARTIK MOHAN KANSALParticipant
Return-Path:
Received: from compute3.internal (compute3.nyi.internal [10.202.2.43])
by sloti21d1t10 (Cyrus 3.5.0-alpha0-141-gf094924a34-fm-20210210.001-gf094924a) with LMTPA;
Tue, 23 Feb 2021 09:27:33 -0500
X-Cyrus-Session-Id: sloti21d1t10-1614090453-1561434-2-10576164737342802730
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-sender-reputation: 500 (none)
X-Spam-score: 3.2
X-Spam-hits: FREEMAIL_ENVFROM_END_DIGIT 0.25, FREEMAIL_FROM 0.001,
HTML_IMAGE_ONLY_16 1.048, HTML_MESSAGE 0.001,
HTML_SHORT_LINK_IMG_2 0.259, ME_SENDERREP_NEUTRAL 0.001,
RCVD_IN_DNSWL_NONE -0.0001, RCVD_IN_MSPIKE_H2 -0.001,
SPF_HELO_NONE 0.001, SPF_PASS -0.001, SUBJ_ALL_CAPS 0.5,
T_REMOTE_IMAGE 0.01, UPPERCASE_75_100 1.189, LANGUAGES en,
BAYES_USED none, SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.208.171′, Host=’mail-lj1-f171.google.com’, Country=’US’,
Received: from mx1 ([10.202.2.200])
by compute3.internal (LMTPProxy); Tue, 23 Feb 2021 09:27:33 -0500
Received: from mx1.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 9BB16660079
for; Tue, 23 Feb 2021 09:27:32 -0500 (EST)
by mx1.messagingengine.com (Authentication Milter) with ESMTP
id 86EA94EFFC2;
1614090452; b=EiIPahLZpv1sXr2YV7CLNO3tW8bGObXbeSBL6UMerPFaHH7qo4
H9zTPVLOlPEmGDeBxnAo4aZhZejT/8T1Mw6nDpLyunpsgDt3ORf27Jvbdn8tYeRv
1VtsubyS7TZkWuehw1eJp3T5AQ95XHQN2TDQ2d63M+FNdvcFBlAS4Gw6+PZx9eUq
jXMDGY2klUxOz0T6N5DNf/74zrJFG+qRHFYQ6fRficSQ3irLM0iY8Rb40G7eP0c8
8O8zUcAUxCTLYu4vbYGDr14gBYXtoljGA2N/pto2h4bzZdJ5JRQ/abuv6GLpfFP4
nra3ibXBbRWKDv+6vf7SKva73UmozY3K8Qbw==
messagingengine.com; h=mime-version:from:date:message-id:subject
:to:content-type; s=fm2; t=1614090452; bh=PgSo2+d1z3yD7KsJjMsN5o
5GPf3Geh5xmlUavYDSslg=; b=AeRg6ICLFJPOsPik4BdFY2VSc/ZJMd35OcFfkR
b+z5TZxrlsbaL4317SzQOdN+lVSDZB/QVMgyKXOxoQHFMOg7sq9fIrJDQHhsnaVk
aICO4pqvGdA2nTbkhLAZvRcBs1rPTZJRF3AiKPcAIq9mJP0DJoOIwuP78opKCO80
9ZFz52iXlVakoqpzmhOzbM+uVIA9gfPDlWM14zci76eyyI7k4KNaj6fSEVyrdzkv
2qTNchgx4+fCnSTtDUW9JyPax+tUElxxJkzIHpeHk/klxxtZhrp+AbXFoPf/Wuvh
/rntZNJIqxyWDBSi1Ayya9tKn8ke+uU8C0GuywfGRcJivNSQ==
ARC-Authentication-Results: i=1; mx1.messagingengine.com;
arc=none (no signatures found);
bimi=skipped (DMARC Policy is not at enforcement);
[email protected] header.b=oHvXLQsa header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.208.171 (mail-lj1-f171.google.com);
spf=pass [email protected]
smtp.helo=mail-lj1-f171.google.com;
x-csa=none;
[email protected] header.b=l8JoaMcI;
x-ptr=pass smtp.helo=mail-lj1-f171.google.com
policy.ptr=mail-lj1-f171.google.com;
(MX Records found: alt3.gmail-smtp-in.l.google.com,alt1.gmail-smtp-in.l.google.com,alt4.gmail-smtp-in.l.google.com,alt2.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com);
x-tls=pass smtp.version=TLSv1.3 smtp.cipher=TLS_AES_256_GCM_SHA384
smtp.bits=256/256;
x-vs=clean score=49 state=0
Authentication-Results: mx1.messagingengine.com;
x-csa=none;
smtp.bits=256/256;
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduledrkeehgdeigecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecuogfuuhhsphgvtghtffhomh
grihhnucdlgeelmdenucfjughrpegghfffkffuvfgtsegrtderredttdejnecuhfhrohhm
pefmrghrthhikhcumfgrnhhsrghluceokhgrrhhtihhkkhgrnhhsrghlvddusehgmhgrih
hlrdgtohhmqeenucggtffrrghtthgvrhhnpeeiieekgeffgeejhefhheffgfdvffeffefg
teeiieefuddthfeileehleegvdehieenucffohhmrghinhepghhoohhglhgvrdgtohhmne
cukfhppedvtdelrdekhedrvddtkedrudejudenucevlhhushhtvghrufhiiigvpedtnecu
rfgrrhgrmhepihhnvghtpedvtdelrdekhedrvddtkedrudejuddphhgvlhhopehmrghilh
dqlhhjuddqfhdujedurdhgohhoghhlvgdrtghomhdpmhgrihhlfhhrohhmpeeokhgrrhht
ihhkkhgrnhhsrghlvddusehgmhgrihhlrdgtohhmqe
X-ME-VSScore: 49
X-ME-VSCategory: clean
X-ME-CSA: none
Received-SPF: pass
receiver=mx1.messagingengine.com;
identity=mailfrom;
client-ip=209.85.208.171
Received: from mail-lj1-f171.google.com (mail-lj1-f171.google.com [209.85.208.171])
(using TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256)
by mx1.messagingengine.com (Postfix) with ESMTPS
Received: by mail-lj1-f171.google.com with SMTP id u4so17742024lja.3
for; Tue, 23 Feb 2021 06:27:32 -0800 (PST)
d=gmail.com; s=20161025;
h=mime-version:from:date:message-id:subject:to;
bh=PgSo2+d1z3yD7KsJjMsN5o5GPf3Geh5xmlUavYDSslg=;
b=oHvXLQsa70gW6F7RuAee467b23CkflKV5FEiV0UCbx9jOb8pWtphc/WvXk2kpwz5di
vd+NeHNNnO1wtmPKiZ3Tcxlz+5SKKRQV7Gp4SlJcPCURtA29itXDZfnLD+O12PYE0sO7
QbGNbydWse3+U9MIrtKyDv4pEglG2ogvs2eJ6j+AMBDIjj6b13W79W6tEv9XI0vWi2Lo
tepluaBh2B47HjG0NqmlCCsL3gIUx0QiRxA3IdAC6jVIU3Pou62dX/fSrFGzahKpmw0/
1dTInuyRpmnA5+zReV9JLmxtfwhVgifZZ0ML3a9KcXttqbAD6nosINav54L9CmLFQ+Ya
ipzw==
d=1e100.net; s=20161025;
h=x-gm-message-state:mime-version:from:date:message-id:subject:to;
b=l8JoaMcILxEKC2zPV4zI9XUcAz9udSRXkxsLRrrLlopOfxNc9prwAW13nlhJKBYleY
PkDb7t/aGPZ/smDHXMD8C589UMmjks0jIe0gGujsq8yQbrf7lL4NfVRWpyEJPiTzaZTn
Qm5EI+qW5Id593QrRJcrEWROLmh1qf89K0MJn6m1HLllYpPqDMQrSgQeqrvr/5LvUf/v
oVyP756Y8sjjdeAX87Pf7vhK7X3tv/yO/8fFZqrUYUGeBxRuoUWPCm9CE3Z246T0vTo3
N1R8r+MgmmoDAC09QoQAa+o6C8QcM1bvAdycK/qX4ltC2kfbzLWxwdIgsUcDAKJ+mONn
C4/w==
X-Gm-Message-State: AOAM530ypS/7Sgl10A1WxgOg9EojKOWU6SzU/hBAzPJWqJ9DsmZceoPF
0ICW9NdB/KN72ffEOb/sfnriaSDezel3R9dA0X2Zmea6tJpK/g==
X-Google-Smtp-Source: ABdhPJwWl2DKSTX58vo0yjxm1ebT8yvzKJD9TGojDprPqjnUew+emBnIOw0XTCidrlmCnU7Q/X3YXondBXvjBX0QfaQ=
X-Received: by 2002:a05:651c:211e:: with SMTP id a30mr17817733ljq.108.1614090449829;
Tue, 23 Feb 2021 06:27:29 -0800 (PST)
MIME-Version: 1.0
Date: Tue, 23 Feb 2021 19:57:18 +0530
Message-ID:
Subject: BRIDGE IS ACTING LIKE DAM
To: [email protected]
Content-Type: multipart/alternative; boundary=”000000000000e5c32f05bc01b7bc”–000000000000e5c32f05bc01b7bc
Content-Type: text/plain; charset=”UTF-8″HELLO,
I AM PREPAIRING A 2D MODEL IN HEC RAS, AND WHEN I AM PLACING THE BRIDGE IT
IS ACTING LIKE DAM . AFTER STIMULATION WATER IS NOT FLOWING FROM BRIDGE,
BRIDGE IS STOPPING WATER LIKE A DAM IT DOES NOT ALLOW WATER TO FLOW.
HERE I AM ATTACHING THE FILE PLEASE KINDLY HELP ME OUT, TO KNOW THAT WHY
THIS PROBLEM IS OCCURING.THANK YOU
TAPI MODEL 2 EXTENDED TERRAIN without culvert.rar
<https://drive.google.com/file/d/1z4SwvDnFY7XMbY2jdf7V07aRxEDulTWe/view?usp=drive_web>–000000000000e5c32f05bc01b7bc
Content-Transfer-Encoding: quoted-printableHELLO,
I AM PREPAIRING A 2D MODEL IN HEC RAS, AND WHEN =
I AM PLACING THE BRIDGE IT IS ACTING LIKE DAM . AFTER STIMULATION WATER IS =
NOT FLOWING FROM BRIDGE, BRIDGE IS STOPPING WATER LIKE A DAM IT DOES NOT AL=
LOW WATER TO FLOW.
HERE I AM ATTACHING THE FILE PLEASE KINDLY HELP ME OU=
T, TO KNOW THAT WHY THIS PROBLEM IS OCCURING.THANK YOU=C2=A0 =C2=A0=
–000000000000e5c32f05bc01b7bc–
