Welcome to the RAS Solution Forums HEC-RAS Help Bridge Geometry
  • #5937
    Karien
    Hi
    I am modelling a exisitng bridge over a river. I am extracting profile data for the bridge levels from C3D.
    This causes the high coord and low coord data to be quite detailed.
    I want to present the longsections to show that the free board is not adequate, but HEC-RAS’s doesn’t display the bridge correctly on the long section.
    When I simplify the bridge data the display is improved, but the analysis output is different.
    I believe the detailed section is more accurate but – it can’t be presented.
    Is there a way to improve the display of the longsection without simplifing the bridge data section.
    Regards.
