Welcome to the RAS Solution Forums HEC-RAS Help Bridge Cross Sections Near Junction
  • This topic has 1 reply, 288 voices, and was last updated 10 years ago by Anonymous.
  • #5826
    I am working on a model of a canal system and am having some trouble entering in the bridge data. The situation I have is one main canal (one reach) that splits into two canals (two separate reaches) at a junction. The bridge is located at the exact spot as the junction. I have the four cross sections cut for a bridge (2 above and 2 below), but when I enter in the bridge station number it does not recognize cross sections from two different reaches and gives an error? Is there a way for the bridge to recognize a cross section from a different reach? Thank you for any help.
    Dan
    #9411
    user
    Have you tried combining the two reaches into one ( use 1 cross section to represent the two reaches) ? As I’m aware , the bridge must be on the same reach to be properly modeled.
