Welcome to the RAS Solution Forums HEC-RAS Help Bridge and culverts stops running
  • #7828
    godzilla
    ver 5.0.7
    have a bridge/culvert, bridge 300′ wide close to beginning of section, culverts spaced far apart for 6000′. Created deck for bridge over river and continued 6000′ for roadway putting 8 (max) culverts. The model ran okay. Got pier info and added to model. Wouldn’t run. Added Multiple Opening Analysis. Runs 1/4 then stops with message “Stagnation points inside bridge opening. Program Aborted in I_Unit”
    I followed instructions about overlapping the range for culverts.
    Do I need to add two bridge/culverts? One for the bridge and one for the road and culverts?
    Do I add one bridge and 2D with a dam with culverts?
    I also can’t login in the web page only in HEC-RAS Help so can’t upload files.
    #12989
    godzilla
    I fixed it. The range for stagnation points were too great. I had overlapping ranges for the bridge to culvert and culvert to culvert. I set all ranges to begin at the end range of the preceding opening type.
    I still can only login when I reset my password and hit the hec-ras help link. I can then post but cannot attach anything. When I post this and logout, the only way back in is to reset password.
