Welcome to the RAS Solution Forums HEC-RAS Help Bridge and Culvert
  • #7080
    Sabina
    1. I have an existing model where a culvert is modelled as a bridge. Is it OK?
    2. How can I model diversion flow during replacement of a culvert?
    Sabina
    #11824
    Scott Miller
    Culverts in HEC are modeled using FHWA standard equations for culvert hydraulics. They can be partially filled with material, which give the culvert a flat bottom.
    In my state, we have a stream crossing guideline that encourages/requires stream simulation culverts. There has to be a channel in the culvert matching the upstream and downstream channel. For this reason I use a bridge with abutments to model a box culvert. I believe using a culvert routine would misrepresent the channel cross section within the culvert.
    A storage area with pumping could be used to model diversion and dewatering. A partially obstructed, upstream culvert may serve as a coffer dam. Be careful not to fully dewater the channel if the model is unsteady.
    #11825
    Sabina
    Thanks a lot Scott.
