Welcome to the RAS Solution Forums HEC-RAS Help Breakline in a 2d area and computation
  • This topic has 7 replies, 1,441 voices, and was last updated 8 years ago by Anonymous.
  • #6679
    Hello guys,
    I am having a basin with 2 main reaches. I want to simulate a flooding event with different approaches. One approach is to create a 2d mesh for the whole basin with a cell size of 30mx30m and increased detail along the reaches by inserting breaklines at the centerlines. If i only had my 30x30m cell size mesh and i insert 10secs of computational interval, will i have to readjust this value after inserting the breaklines? Maybe because of the increased information at those points? (smaller value?).
    Thank you in advance
    Paul
    #10990
    Basically the question should also include if it is correct to insert a breakline at the centerline of a stream in order to increase the detail of a computational mesh.
    #10991
    Your computational time step doesnt necessarily have to change after a mesh is adjusted or further defined but that all depends on the final result.
    IMO i do not think a stream centerline should be a breakline but rather the streams channel banks.
    #10992
    Correct.
    Thank you Luis
    #10993
    You could use a stream centerline as a breakline or banks as breaklines. It all depends on the river, how wide it is, and your cell size.
    #10994
    That’s right. In my case the rivers are approximately 7 to 16 meters wide. I ‘ve set a 30x30m grid and up to 10m cells at the rivers. I think i’ll go with the stream centerline.
    #10995
    robdir
    Look at pag.4.3-4.5 (Chapter 4 of 2D Modeling User’s Manual)…
    Your Computation Interval should respect the Courant number (as described at pag.4.5).
    If you insert breaklines along the main stream or banks you couldn’t ignore it.
    #10996
    Yes. Practically the best case would be to compute the Courant number for the maximum velocity assumed for your 2d cells.
