I am completing a 1D Hec-RAS model and I am modelling a smaller tributary that outlets into a larger river.
Is it better to use normal depth or a known water surface elevation? The only water surface elevation data I have is from a model developed 25 years ago.  At the most downstream cross sections the difference in depth between normal depth and the known water surface elevation are around 1 foot.  Is it better to just use the most conservative value if I have no data to calibrate or validate?
Thank you.
