Welcome to the RAS Solution Forums HEC-RAS Help Beaver Dam Weir Coefficient
  • #16208
    Scott Miller
    The Weir Equations in HEC-RAS post in The RAS Solution has a usable diagram for effective coefficient. It takes the relative width and relative depth of a weir into account, but what about roughness? How should characteristics of a beaver dam or debris berm be taken into account (if modeled)?
    #16745
    Luis Partida
    If it is 1D, I would increase the roughness coefficient of the US and DS cross sections. If it is 2D I would also adjust the associated cells roughness coefficient assuming they were small enough to not impact adjacent cells.
    Another option could be to model the weir as a cross section with Lids. In this instance you could correlate an exact cross section with a weir and associated roughness coefficient. You could also add a minor loss coefficient to the model in the Table of the geometry data editor.
