Welcome to the RAS Solution Forums HEC-RAS Help Bank Lines in RAS Mapper
  • This topic has 1 reply, 809 voices, and was last updated 6 years ago by Anonymous.
  • #7406
    I’m struggling with a bank lines issue in the RAS Mapper window. I have assigned the bank stations as normal, however, in the RAS Mapper, the presented bank lines are really weird. It just cut from the US end to the DS end, or even to another reach. Those lines are really off at an area of multiple junctions. And I used long cross sections over two reaches for this area.
    For the rest area, it seems alright. Would anyone have some idea what it is causing this? And will it impact the calculation?
    Thank you very much!
    #12458
    You can update the banklines in Mapper to match the bank points which should match what you set in the cross-section editor.
    To do this go to edit mode and right click on the banklines.
