Welcome to the RAS Solution › Forums › HECRAS Controller › Automatic Controls
- This topic has 4 replies, 364 voices, and was last updated 7 years, 1 month ago by AlbertClemmens.
February 20, 2019 at 3:35 am #8228AlbertClemmensParticipant
Everything I read suggest that the commands in your book, when used with VB.net are either run before or after a HEC-RAS plan is run. I know you ran HEC-RAS in real time and allowed gates to be controlled (CAP training tool). Did you just run multiple plans, or were the controls run in VBA, or?
Thanks your help would be appreciated.February 21, 2019 at 5:48 am #13606Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.1.5-895-g0d23ba6-fmstable-20190213v1) with LMTPA;
Wed, 20 Feb 2019 20:52:47 -0500
X-Cyrus-Session-Id: sloti1d2t14-1550713967-2267016-2-11756844100867424662
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 1.3
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_ZS_CLEAN -0.001,
MIME_QP_LONG_LINE 0.001, RCVD_IN_DNSWL_NONE -0.0001, SPF_PASS -0.001,
URI_HEX 1.313, LANGUAGES en, BAYES_USED none, SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.214.173′, Host=’mail-pl1-f173.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
Received: from mx2 ([10.202.2.201])
by compute1.internal (LMTPProxy); Wed, 20 Feb 2019 20:52:47 -0500
Received: from mx2.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 3A4FAD90C3
for; Wed, 20 Feb 2019 20:52:46 -0500 (EST)
by mx2.messagingengine.com (Authentication Milter) with ESMTP
id C50CD6071B8;
1550713966; b=Mdyfm92qZ4xJajJKTPDXKB++6Lfwrw3w7JzhgOQUoy1V+RT21s
HeiFOxTDEn6E03vD1hQchNsqx2gl+wI144x1NrQb+xngZvlk4wAl3mSHivxkh9Or
/+Y4uPp5716sKlU84kjxWDYxc0EgQaYK5htDdTLx27jmsrNcKjNvcfiWNbkyrwp/
OAbAVvSam9Op/b2p3KSy+nGWLQGTYYIK/REW1nAxpqA2rGPOpH6u2kpccna8jUpk
1gADlMu3rwBTHlqWiD9fZiuMcA2Lq6yR3uVKMdD6iiOLDvGZzXaa0jWGsOBjHsR8
oor3gaz/cHyPNrJFguw4FeW5HCDEloHf4sQA==
messagingengine.com; h=from:content-type
:content-transfer-encoding:mime-version:date:subject:message-id
:references:in-reply-to:to; s=fm2; t=1550713966; bh=KMRfPP1e8NTw
oWjdAcEMDGXLWLEg/I9R7YcJRczdoEc=; b=H1mnXiNNDIMZouvBzgG7kqdiUNR+
8RCXx2bInnZhwAPa6uufi5J0QNOv7TwwqpkYGXneM9PkXgrCLE+X76DYRyrf/aGF
SYCrrkuaXgkxbi1po5CZ0MwIuvNBim6ToqoKeB0mxFXtxXHfaJhYiOEYE42CwDNw
8o2MDE2M/pkv4qkYs19oANhDdKwiZepAsh6B5uEO3jgknQJjyUzbzdGj3hRrA6fV
whA4EcB6my8qa6GkMyRpVQYAlF6cxTmiX+eLDvj/ldTk4IYY4aS1zx39YSej7lLo
m5wYwNX8MaOCKlCIHRWB/IWnJSveAlUsPQt3inh1pWX+h0mcaFNUpIJ4MQ==
ARC-Authentication-Results: i=1; mx2.messagingengine.com; arc=none (no signatures found);
[email protected] header.b=ol4wdEgC header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.214.173 (mail-pl1-f173.google.com);
spf=pass [email protected]
smtp.helo=mail-pl1-f173.google.com;
[email protected] header.b=T3DoaGMZ;
x-ptr=pass smtp.helo=mail-pl1-f173.google.com
policy.ptr=mail-pl1-f173.google.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=0 state=0;
x-zs=clean
Authentication-Results: mx2.messagingengine.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-zs=clean
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0x
MTg0JmNvZGU9ZEdobGNtRnpjMjlzZFhScGIyNUFaMjFoYVd3dVkyOXRmREV4T0RSOE1URT
NORGc1TkRneE5RPT0
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedutddrtdejgdeflecutefuodetggdotefrodftvf
curfhrohhfihhlvgemucfhrghsthforghilhdpggftfghnshhusghstghrihgsvgdpuffr
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecunecujfgurhephfgtgfggff
fukfhfjgfvofesrgejmherhhdtjeenucfhrhhomhepvfhhvgcutfetufcuufholhhuthhi
ohhnuceothhhvghrrghsshholhhuthhiohhnsehgmhgrihhlrdgtohhmqeenucffohhmrg
hinhepvhgsrdhnvghtpdhnrggssghlvgdrtghomhenucfkphepvddtledrkeehrddvudeg
rddujeefpdejfedrfeejrdekgedrudduheenucfrrghrrghmpehinhgvthepvddtledrke
ehrddvudegrddujeefpdhhvghlohepmhgrihhlqdhplhduqdhfudejfedrghhoohhglhgv
rdgtohhmpdhmrghilhhfrhhomhepoehthhgvrhgrshhsohhluhhtihhonhesghhmrghilh
drtghomhequcfukfgkgfepieeljeelnecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSScore: 0
X-ME-VSCategory: clean
X-ME-ZSResult: clean
Received-SPF: pass
receiver=mx2.messagingengine.com;
identity=mailfrom;
client-ip=209.85.214.173
Received: from mail-pl1-f173.google.com (mail-pl1-f173.google.com [209.85.214.173])
by mx2.messagingengine.com (Postfix) with ESMTPS
for; Wed, 20 Feb 2019 20:52:45 -0500 (EST)
Received: by mail-pl1-f173.google.com with SMTP id bj4so13262907plb.7
for; Wed, 20 Feb 2019 17:52:45 -0800 (PST)
d=gmail.com; s=20161025;
h=from:content-transfer-encoding:mime-version:date:subject:message-id
bh=KMRfPP1e8NTwoWjdAcEMDGXLWLEg/I9R7YcJRczdoEc=;
b=ol4wdEgCfEeAsrZjN9czz+p7nEF/h75Lil1BlaKEz3XRCJ4ystMcNXnDiUKwQhpAxN
hhDEsY+ylWrOLLx3BR7XfdBTXenxkeTkjseL8bloDYamQ4GN/13rAjQc/CVfi4U5+MQU
8YLT9g2Qa5dCKtfOqUU/RmODxbB+xVwd69Zj8Z9B16YlliCA1OjuOd3BgWmGp5uQEmJS
BKUxDoSqEH0Dhy5fxd/ht+Tm7J9lLvfI/SFUUEgz/Ue8rR32uPzICPrmpMCzdKyo7RhR
+IhoD+MBbwXGY9kCn2ZOJB2lk4BXmqQIXJU1CMXq2oJFQ3iEtBZaELaesZwvkwEOTGsg
MMLQ==
d=1e100.net; s=20161025;
h=x-gm-message-state:from:content-transfer-encoding:mime-version:date
:subject:message-id:references:in-reply-to:to;
b=T3DoaGMZN7ODCSn7VFLVg3JFDmDTUSwYKP+pblmRp/LCbN9Svo57hgMFLuXZO3yNIL
T33S/7Ybv2gPfly8TjOm0XcyBdJo7uEvI0iYtPnfQCDRvLKpgqrwaz5CpgjW8Mp7LFsl
T9P53P8KGjhn2Y2/rzRyHx3ReL99Q4Kz+cCCkJKg7mey0oB0A4JUiYIGdOMuTCHEE+nG
TgBNA3d6ka/G8Ntqv+t7LgKlg5YrVEDhJzEXYOWWDhawTk5YWFqdI9Da9gxD4HDuQWG0
qReYqFxbL00EUqgca9vKA/DcUxg1tqlDTO9vhePQKFtoBXldFWar/+U5UUdN5+Hzu3bl
AaPQ==
X-Gm-Message-State: AHQUAuZRK4ere9Lj4t+MQYYeXnQEQaVkF2K+eu0Wp4wYKkmuOaVC7RhN
MVqMfwPP2AsHjx/93IjYhVXpqnI7
X-Google-Smtp-Source: AHgI3IYw2QIVYzLvxMO+6dKYzMVvcBk3eEd/qKQl/ub/BCr93ENi6IfpLAHbSDOspTEwo3zd+AXTog==
X-Received: by 2002:a17:902:8d97:: with SMTP id v23mr6010770plo.274.1550713963105;
Wed, 20 Feb 2019 17:52:43 -0800 (PST)
Received: from [192.168.1.14] (c-73-37-84-115.hsd1.or.comcast.net. [73.37.84.115])
by smtp.gmail.com with ESMTPSA id f14sm22431042pgv.23.2019.02.20.17.52.41
for
(version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
Wed, 20 Feb 2019 17:52:41 -0800 (PST)
boundary=Apple-Mail-A2A05A9B-7461-4EBC-A2E0-4EE67F43A9EE
Mime-Version: 1.0 (1.0)
Date: Wed, 20 Feb 2019 17:52:40 -0800
Subject: Re: Automatic Controls
To: “AlbertClemmens [via HEC-RAS Help]”
X-Mailer: iPhone Mail (16D57)–Apple-Mail-A2A05A9B-7461-4EBC-A2E0-4EE67F43A9EE
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printableHi Bert. To do that we set up the RAS model to =E2=80=9Cpause=E2=80=9D every=
minute. Essentially we were inning one minute simulations while writing a r=
estart file after each run. The next run would then start up where the last o=
ne ended and would just change offtake gate settings in between.=20Sent from my iPhone
> On Feb 19, 2019, at 3:35 PM, AlbertClemmens [via HEC-RAS Help]
wrote:
>=20
> Everything I read suggest that the commands in your book, when used with V=
B.net are either run before or after a HEC-RAS plan is run. I know you ran H=
EC-RAS in real time and allowed gates to be controlled (CAP training tool). D=
id you just run multiple plans, or were the controls run in VBA, or?=20
> Thanks your help would be appreciated.=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Automatic-Controls-tp7216.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-A2A05A9B-7461-4EBC-A2E0-4EE67F43A9EE
Hi Bert. To do that we set up the RAS model=
Content-Type: text/html;
charset=utf-8
to =E2=80=9Cpause=E2=80=9D every minute. Essentially we were inning one min=
ute simulations while writing a restart file after each run. The next run wo=
uld then start up where the last one ended and would just change offtake gat=
e settings in between.Sent from my iPhoneOn Feb 19, 2019, at 3:35 PM=
, AlbertClemmens [via HEC-RAS Help] <[email protected]> wrote:Everything I read suggest that the commands in your book, when used=
with VB.net are either run before or after a H=
EC-RAS plan is run. I know you ran HEC-RAS in real time and allowed gates to=
be controlled (CAP training tool). Did you just run multiple plans, or were=
Thanks your help would be appreciated.=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Automati=
To start a new topic under HECRAS Controller, email [email protected].=
com
NAML=
–Apple-Mail-A2A05A9B-7461-4EBC-A2E0-4EE67F43A9EE–
February 21, 2019 at 9:20 pm #13607AlbertClemmensParticipantReturn-Path:
Thu, 21 Feb 2019 12:20:47 -0500
X-Cyrus-Session-Id: sloti1d2t14-1550769647-282915-2-4464392972252032107
X-Spam-score: 1.3
X-Spam-hits: HTML_MESSAGE 0.001, ME_NOAUTH 0.01, ME_ZS_CLEAN -0.001,
RCVD_IN_DNSWL_NONE -0.0001, URI_HEX 1.313, LANGUAGES en, BAYES_USED none,
SA_VERSION 3.4.2
X-Spam-source: IP=’108.166.43.112′, Host=’smtp112.ord1c.emailsrvr.com’, Country=’US’,
FromHeader=’com’, MailFrom=’com’, XOriginatingCountry=’US’
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Thu, 21 Feb 2019 12:20:47 -0500
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id C54FD46056
for; Thu, 21 Feb 2019 12:20:46 -0500 (EST)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id 972D788EDEF;
1550769646; b=eQp96fA8uwdDxfKXhTbpU1+SJClF242dl8fAzEbmEnrigZ87HE
Qin5mH57tPQyG20aSRdn+5HuOfCwoPzOrKhx/a4FSGQlPi+HpPqDGPnx6ah903Q8
45qYEolCQKIGBU/j2MtVs81ngnHcENU/EqaB56c8DA3VtiPumzIoD8DohNoTuSHk
P5a9wU5RdJ03FIRqXv72JT4VOPkHi0lh8+zxDOmFMIjq3XHJklYyyaf7Zo8nA2mn
DnoKM/u8ZUzjAd9uB8H6BFkUkN0jMNneBEyXMwusoBcRvvT0dKy2M5r5CLUGZboE
jEbBNxsZT6DvU6YSH1Hfk3ZZ0Somp62AUpcg==
messagingengine.com; h=from:to:subject:date:message-id
:references:in-reply-to:content-type:mime-version; s=fm2; t=
1550769646; bh=AL8FvVUhvTcvPofywCTAV1hpdJqbjbMJyxCIpG/rb1w=; b=U
3Ap9X7K217fX0nLpZ3KMhpFAjev1h5AbOanbcKW8BaQcpNl4ghAc2ygDxMpHRgUD
7bYj4mOrfDA6xkH0KInePbAHuACUflDpbAJU/DP+KPDujusNOFTpGAAPVnSccV8t
r+KQIFxugh2pBrdkGYCwTdWZht2Sk7KRLDw5BPehNDH9AG/zJ5taZiEW0eRFavXO
xOi1lGsLYP9XsjxOF+ZnM8BRGOnXrIat0BzA+hKXkpJVA6sHP+Pz4skl9662cmz1
dsameXUX0jezhdC8/gB+XQIyX8qMLbmP7k561oC5FZFnesRstxF7J6FkJJjfEoTk
3v92jVAuT/PmIS5bEwE2w==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
dkim=none (no signatures found);
dmarc=none policy.published-domain-policy=none
(p=none,d=none,d.eval=none) policy.policy-from=p
header.from=westconsultants.com;
iprev=pass smtp.remote-ip=108.166.43.112 (smtp112.ord1c.emailsrvr.com);
spf=none [email protected]
smtp.helo=smtp112.ord1c.emailsrvr.com;
x-ptr=pass smtp.helo=smtp112.ord1c.emailsrvr.com
policy.ptr=smtp112.ord1c.emailsrvr.com;
x-return-mx=pass header.domain=westconsultants.com policy.is_org=yes
(MX Record found);
x-return-mx=pass smtp.domain=westconsultants.com policy.is_org=yes
(MX Record found);
smtp.bits=128/128;
x-zs=clean
Authentication-Results: mx3.messagingengine.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-zs=clean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bWwhbmFiYmxlJTNBZW1haWwubmFtbCZiYXNlPW5hYmJsZS5uYW1sLm5hbWVzcGFjZXMuQm
FzaWNOYW1lc3BhY2UtbmFiYmxlLnZpZXcud2ViLnRlbXBsYXRlLk5hYmJsZU5hbWVzcGFj
ZS1uYWJibGUudmlldy53ZWIudGVtcGxhdGUuTm9kZU5hbWVzcGFjZSZicmVhZGNydW1icz
1ub3RpZnlfc3Vic2NyaWJlcnMhbmFiYmxlJTNBZW1haWwubmFtbC1pbnN0YW50X2VtYWls
cyFuYWJibGUlM0FlbWFpbC5uYW1sLXNlbmRfaW5zdGFudF9lbWFpbCFuYWJibGUlM0FlbW
FpbC5uYW1s
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedutddrtdekgddutddtucetufdoteggodetrfdotf
fvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgfnhhsuhgsshgtrhhisggvpdfu
rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucenucfjughrpefhvffuth
ffkfhfjghitgggsegrtdelredttdejnecuhfhrohhmpeeuvghrthcuvehlvghmmhgvnhhs
uceosggtlhgvmhhmvghnshesfigvshhttghonhhsuhhlthgrnhhtshdrtghomheqnecuff
homhgrihhnpehvsgdrnhgvthdpnhgrsggslhgvrdgtohhmpdhthhgvrhgrshhsohhluhht
ihhonhdrtghomhenucfkphepuddtkedrudeiiedrgeefrdduuddvpdeijedriedtrddutd
ekrddvvdehpdhfvgektdemmeelvdgvvdemsggrfhhfmehfvgdvtdemtgegugeknecurfgr
rhgrmhepihhnvghtpedutdekrdduieeirdegfedrudduvddphhgvlhhopehsmhhtphduud
dvrdhorhguudgtrdgvmhgrihhlshhrvhhrrdgtohhmpdhmrghilhhfrhhomhepoegstghl
vghmmhgvnhhsseifvghsthgtohhnshhulhhtrghnthhsrdgtohhmqecuuffkkgfgpeduie
eiheeknecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSScore: 0
Received-SPF: none
(westconsultants.com: No applicable sender policy available)
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=108.166.43.112
Received: from smtp112.ord1c.emailsrvr.com (smtp112.ord1c.emailsrvr.com [108.166.43.112])
by mx3.messagingengine.com (Postfix) with ESMTPS
for; Thu, 21 Feb 2019 12:20:45 -0500 (EST)
Received: from smtp23.relay.ord1c.emailsrvr.com (localhost [127.0.0.1])
by smtp23.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTP id 8B7E04019E
for; Thu, 21 Feb 2019 12:20:44 -0500 (EST)
Received: from smtp192.mex05.mlsrvr.com (unknown [184.106.31.85])
by smtp23.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTPS id 64AB5403AF
X-Sender-Id: [email protected]
Received: from smtp192.mex05.mlsrvr.com ([UNAVAILABLE]. [184.106.31.85])
(using TLSv1 with cipher DHE-RSA-AES256-SHA)
by 0.0.0.0:25 (trex/5.7.12);
Received: from ORD2MBX03H.mex05.mlsrvr.com ([fe80::92e2:baff:fe20:c4d8]) by
ORD2HUB10.mex05.mlsrvr.com ([fe80::d6ae:52ff:fe7f:6620%15]) with mapi id
14.03.0382.000; Thu, 21 Feb 2019 11:20:43 -0600
To: “Chris G. [via HEC-RAS Help]”
Subject: RE: Automatic Controls
Thread-Topic: Automatic Controls
Thread-Index: AQHUyYgqVyjIksIks0epJX818qns/aXqgGyg
Date: Thu, 21 Feb 2019 17:20:43 +0000
Message-ID:
<[email protected]>
Accept-Language: en-US
Content-Language: en-US
X-MS-Has-Attach:
X-MS-TNEF-Correlator:
x-originating-ip: [67.60.108.225]
boundary=”_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5931ORD2MBX03Hmex05_”
MIME-Version: 1.0–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5931ORD2MBX03Hmex05_
Content-Type: text/plain; charset=”utf-8″
Content-Transfer-Encoding: base64VGhhbmtzLg0KDQpCZXJ0IENsZW1tZW5zLCBQaEQsIFBFLCAgRC5XUkUNClNlbmlvciBIeWRyYXVs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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5931ORD2MBX03Hmex05_
Content-Type: text/html; charset=”utf-8″
Content-Transfer-Encoding: base64PGh0bWwgeG1sbnM6dj0idXJuOnNjaGVtYXMtbWljcm9zb2Z0LWNvbTp2bWwiIHhtbG5zOm89InVy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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5931ORD2MBX03Hmex05_–
February 22, 2019 at 4:01 am #13608AlbertClemmensParticipantReturn-Path:
Thu, 21 Feb 2019 19:02:10 -0500
X-Cyrus-Session-Id: sloti1d2t14-1550793730-1253190-2-9917153407610645684
X-Spam-score: 1.3
SA_VERSION 3.4.2
X-Spam-source: IP=’108.166.43.120′, Host=’smtp120.ord1c.emailsrvr.com’, Country=’US’,
by compute1.internal (LMTPProxy); Thu, 21 Feb 2019 19:02:10 -0500
by mailmx.nyi.internal (Postfix) with ESMTP id F3000C829F
for; Thu, 21 Feb 2019 19:02:09 -0500 (EST)
id 00621517C5F;
1550793729; b=Zkx/Y4vTmm8JqCeZVPwJV5ZxRjPz06f4aIgZ1KFtcp5AGMPab/
mKEjR64QlsSa3oBoIWp9OE6+l0m/4tSm13LtIw2DKFJtMGU5q/jDwC4wh1qB9En5
EmZLoBVQFekyFHe++vfZuIebZHGmRSPEbO4dCXjInWtVnRHFXhwLhVstStLC+MAB
3WysjYgpFpQ+slhz07uLwVSy3UQ1cpQlf5ny5J+KX2lViZfJ/uORVQQMmljVq8Xc
CMo8l7oxSlU0MUek/i8WbTlKv3BHUXM8mrpzSTUU1IpKLBa/QvOlBpf/8oQ7gUjI
SDCQZBANfEHkx+m1l3oxgfyC3SswHfoXmBtg==
messagingengine.com; h=from:to:cc:subject:date:message-id
1550793729; bh=gNT+q+fIsuHsVW8CO8DALTNremEtyKsrhPV5NJcyU8c=; b=Q
B5tSRU5QX02tdJEq7uvMI7kMMvXMSpSAp9c5o0yhG45echDEiUFJjCVIjktqn1cq
bBTu45Y3AVzAcwSHxsL0Ib1Eqd6JjI2wRFbMugfHDK3XfXcjaKqlwaM5Yo8NSiI9
fXPq0+5Q1pFSWjMx+YcqkfJ2ie35Ra0MJhtAgAfjn5be5xT36aPNJPUY5Kg6+FlM
uhWiSf0imXHYfZFU8huqQZU4owrIAn1OIIXfMryZVZHLHb4qai3GTFequFtMpnVZ
NaFpo2wsroI6XFvj+94xleKt5YO6nrqf1sicPl4af9+7Bis8opPeYqt0rOxJPizE
HMfXg7vn69rRoanlnMObA==
ARC-Authentication-Results: i=1; mx4.messagingengine.com; arc=none (no signatures found);
iprev=pass smtp.remote-ip=108.166.43.120 (smtp120.ord1c.emailsrvr.com);
smtp.helo=smtp120.ord1c.emailsrvr.com;
x-ptr=pass smtp.helo=smtp120.ord1c.emailsrvr.com
policy.ptr=smtp120.ord1c.emailsrvr.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-vs=clean score=-100 state=0;
x-zs=clean
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-zs=clean
FpbC5uYW1s
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedutddrtdelgdduhecutefuodetggdotefrodftvf
tefokffrpgfnqfghnecuuegrihhlohhuthemuceftddtnecusecvtfgvtghiphhivghnth
hsucdlqddutddtmdenucfjughrpefhvffuthffkfhfjghitgggsegrtdelredttdejnecu
hfhrohhmpeeuvghrthcuvehlvghmmhgvnhhsuceosggtlhgvmhhmvghnshesfigvshhttg
honhhsuhhlthgrnhhtshdrtghomheqnecuffhomhgrihhnpehvsgdrnhgvthdpnhgrsggs
lhgvrdgtohhmpdhthhgvrhgrshhsohhluhhtihhonhdrtghomhenucfkphepuddtkedrud
eiiedrgeefrdduvddtpdeijedriedtrddutdekrddvvdehpdhfvgektdemmeelvdgvvdem
sggrfhhfmehfvgdvtdemtgegugeknecurfgrrhgrmhepihhnvghtpedutdekrdduieeird
egfedruddvtddphhgvlhhopehsmhhtphduvddtrdhorhguudgtrdgvmhgrihhlshhrvhhr
rdgtohhmpdhmrghilhhfrhhomhepoegstghlvghmmhgvnhhsseifvghsthgtohhnshhulh
htrghnthhsrdgtohhmqecuuffkkgfgpeduleefudeknecuvehluhhsthgvrhfuihiivgep
td
X-ME-VSScore: -100
Received-SPF: none
identity=mailfrom;
client-ip=108.166.43.120
Received: from smtp120.ord1c.emailsrvr.com (smtp120.ord1c.emailsrvr.com [108.166.43.120])
Received: from smtp16.relay.ord1c.emailsrvr.com (localhost [127.0.0.1])
by smtp16.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTP id D2E2DC0182
for; Thu, 21 Feb 2019 19:02:07 -0500 (EST)
by smtp16.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTPS id A3A0AC03D2
ORD2HUB06.mex05.mlsrvr.com ([fe80::b470:61fb:3d7e:9f49%20]) with mapi id
14.03.0382.000; Thu, 21 Feb 2019 18:01:36 -0600
CC: Brian Wahlin
Thread-Index: AQHUyYgqVyjIksIks0epJX818qns/aXq62yQ
Date: Fri, 22 Feb 2019 00:01:36 +0000
Message-ID:
<[email protected]>
X-MS-Has-Attach:
boundary=”_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5A84ORD2MBX03Hmex05_”
MIME-Version: 1.0–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5A84ORD2MBX03Hmex05_
Content-Transfer-Encoding: base64SSBhbSBsb29raW5nIGludG8gaG93IHRvIGRvIHRoaXMgYW5kIGhhdmUgYSBmZXcgcXVlc3Rpb25z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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5A84ORD2MBX03Hmex05_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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5A84ORD2MBX03Hmex05_–
February 23, 2019 at 9:21 pm #13609AlbertClemmensParticipantReturn-Path:
Sat, 23 Feb 2019 12:25:39 -0500
X-Cyrus-Session-Id: sloti1d2t14-1550942739-2629202-2-15402245000660226230
X-Spam-score: 1.3
SA_VERSION 3.4.2
X-Spam-source: IP=’108.166.43.88′, Host=’smtp88.ord1c.emailsrvr.com’, Country=’US’,
Received: from mx6 ([10.202.2.205])
by compute1.internal (LMTPProxy); Sat, 23 Feb 2019 12:25:39 -0500
Received: from mx6.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id 49D474226E
for; Sat, 23 Feb 2019 12:25:38 -0500 (EST)
by mx6.messagingengine.com (Authentication Milter) with ESMTP
id D81F6DE894E;
1550942738; b=v+S6UIw492aITkr1YPNSNMFP53R+rd41LNxdWJi0beB2RhbIj5
M8TJDn6cSo2Ygq3cG+ZZY684m3yUJmigxkzed/j4eo1gmHSIlX6lZuHIYLUuR6Y2
gv1+NoILKzPaHpKLTTdBGuK0Iz0TErnaVDde87zs2ckxSGhsGCy75pk4rQn2UxZm
5nQRKR7AdVl+/GkFlhKph1+9PuFdAUYxPVY6bwPeERgZ+J2Jy9dLD0yv1RRwfT2P
sbk6IqpIiS6JiWcfbixklYjXmDDrm+X/NNQh/hgBw19rNTubj+W74kTswpB4MP51
JzulFEJknXvgLxSUCvFXjK+8CbADVY0XRcQw==
1550942738; bh=kl92g6FB5U0HsqF18UGHkrVAnZD+4jitO7dLNPU0P7A=; b=E
WxaxUJ0FqEHylUDHd4+oO0GV8vvH/wOjUNRsFk8DlpvZwqqFbyRoLweNbYixtR3G
FmORO/OF3FuqqLp7aflRYpasgh2yM90IXFM6G8UZxyprYblic7mBlk/zRh1B130h
oCpq5U2Tlg72ckzhEPzYYgen30wv1krTgaImUYWeG7s/xOuQUqd7Z0ghBomN/nc+
9nic9/3gBEZ1KqqUC/7Hchnf+C6g7WQhlCqNUAddy71QtcsQ+U593k03kI/T2Mbv
d2PuCmNWihbSvA9C//5Tz8/X1ZBekA2mwbF9GlQJzZME/B8fAW+kAwr4LNXCiHw9
2w2vQfwcORLQAojsGYi1A==
ARC-Authentication-Results: i=1; mx6.messagingengine.com; arc=none (no signatures found);
iprev=pass smtp.remote-ip=108.166.43.88 (smtp88.ord1c.emailsrvr.com);
smtp.helo=smtp88.ord1c.emailsrvr.com;
x-ptr=pass smtp.helo=smtp88.ord1c.emailsrvr.com
policy.ptr=smtp88.ord1c.emailsrvr.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-zs=clean
Authentication-Results: mx6.messagingengine.com;
(MX Record found);
(MX Record found);
smtp.bits=128/128;
x-zs=clean
FpbC5uYW1s
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgedutddruddvgddutdduucetufdoteggodetrfdotf
rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucesvcftvggtihhpihgvnh
htshculddquddttddmnecujfgurhephffvufhtfffkfhgjihgtggesrgdtleertddtjeen
ucfhrhhomhepuegvrhhtucevlhgvmhhmvghnshcuoegstghlvghmmhgvnhhsseifvghsth
gtohhnshhulhhtrghnthhsrdgtohhmqeenucffohhmrghinhepvhgsrdhnvghtpdhnrggs
sghlvgdrtghomhdpthhhvghrrghsshholhhuthhiohhnrdgtohhmnecukfhppedutdekrd
duieeirdegfedrkeekpdeijedriedtrddutdekrddvvdehpdhfvgektdemmeelvdgvvdem
egfedrkeekpdhhvghlohepshhmthhpkeekrdhorhguudgtrdgvmhgrihhlshhrvhhrrdgt
ohhmpdhmrghilhhfrhhomhepoegstghlvghmmhgvnhhsseifvghsthgtohhnshhulhhtrg
hnthhsrdgtohhmqecuuffkkgfgpedvtdehieegnecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSScore: -100
Received-SPF: none
receiver=mx6.messagingengine.com;
identity=mailfrom;
client-ip=108.166.43.88
Received: from smtp88.ord1c.emailsrvr.com (smtp88.ord1c.emailsrvr.com [108.166.43.88])
by mx6.messagingengine.com (Postfix) with ESMTPS
for; Sat, 23 Feb 2019 12:25:37 -0500 (EST)
Received: from smtp28.relay.ord1c.emailsrvr.com (localhost [127.0.0.1])
by smtp28.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTP id 26B3740263
for; Sat, 23 Feb 2019 12:25:36 -0500 (EST)
by smtp28.relay.ord1c.emailsrvr.com (SMTP Server) with ESMTPS id EDF6740260
for; Sat, 23 Feb 2019 12:25:35 -0500 (EST)
ORD2HUB17.mex05.mlsrvr.com ([fe80::be30:5bff:feee:e494%15]) with mapi id
14.03.0382.000; Sat, 23 Feb 2019 11:25:35 -0600
CC: Brian Wahlin
Thread-Index: AQHUyYgqVyjIksIks0epJX818qns/aXto0WQ
Date: Sat, 23 Feb 2019 17:25:34 +0000
Message-ID:
<[email protected]>
X-MS-Has-Attach:
boundary=”_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5DF6ORD2MBX03Hmex05_”
MIME-Version: 1.0–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5DF6ORD2MBX03Hmex05_
Content-Transfer-Encoding: base64VGhhbmtzLiBJIGRvIGhhdmUgYSBmZXcgcXVlc3Rpb25zDQoNCiAgMS4gIERpZCB5b3Ugd3JpdGUg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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5DF6ORD2MBX03Hmex05_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–_000_AB5E07E74FE5C449B4D40FBF89B67EC4482A5DF6ORD2MBX03Hmex05_–
