Welcome to the RAS Solution Forums HECRAS Controller Automate Terrain and LandCover association
  • This topic has 5 replies, 543 voices, and was last updated 8 years ago by Anonymous.
  • #8203
    Hi Chris and community in large:
    I am automating a large number of hec-ras runs using RASController version 503. The workflow is pretty straightforward.
    The main issue is the association of geometry and results with a terrain and a land cover dataset. I can certainly do that in the RAS mapper interface, but in the automated runs this is a problem. It seems the association is saved in the geometry hdf file and the plan hdf file, which can only be done through the RAS Mapper interface. Is there a way in RASController to setup the association with Terrain and Landcover?
    #13560
    An update here, I think RAS Mapper will find the first available terrain dataset to associate with geometry. So, that resolve a part of the issue, but still it won’t automatically associate with a land cover dataset and it won’t automatically associate terrain with results either. So, can RAS Controller do that?
    #13561
    Another update, I was able to programmatically (not using RAS Controller) manipulate the binary file to get both terrain and land cover data association with geometry defined, the last remaining piece is the association of terrain with the results, which seems to be only possible through the ras mapper. Any thought?
    #13562
    Tong Zhai
    Ok, final update on my own effort, I was able to programmatically (not using RAS Controller) to associate land cover data and terrain with both geometry and results through updating binary files. So, for the moment, my issue has been resolved.
    My final question, can RASController do such association setting?
    #13563
    Toby
    Hi Tong Zhai,
    Thanks for sharing this info! Have you been modifying the *.rasmap file to update your terrain and land class data?
    thanks,
    #13564
    As far as I know, there are no controls for RASMapper within RASController.
