Welcome to the RAS Solution Forums HEC-RAS Help analysing a part of the reach
  • This topic has 2 replies, 282 voices, and was last updated 9 years ago by Anonymous.
  • #6349
    I have around 6 reaches in my model but I’d like to run them individually first by assigning boundary conditions to one reach at a time. is it possible in Hec-RAs 5.01/5.03? Id so, could anyone walk me through it? Thanks in advance.
    #10391
    dueckrandy
    The only type of boundary condition you can apply to a cross section in the middle of a river element is a rating curve – stage/discharge. This would let you force a defined water surface elevation at any cross section.
    If you want to apply a normal depth boundary condition with a slope, you would have to model each reach as a separate river. You could then join the rivers by selecting Edit>Move Points/objects and moving the vertices to overlap where you want to create a junction between rivers.
    Hope this helps!
    #10392
    Bharath
    Thanks a lot for the information. I can add a rating curve at the last bridge in the reach. In that case, it should be possible for me to run for individual reaches right?
