Welcome to the RAS Solution › Forums › HEC-RAS Help › Adding tributary to an existing reach on RAS map not working on HEC-RAS 6.2
- This topic has 1 reply, 2 voices, and was last updated 3 years, 8 months ago by Luis Partida.
June 13, 2022 at 9:11 pm #15898Vannary SengParticipant
It seems to be a bug in HEC-RAS 6.2. I kept getting the error message as shown below when I tried to add a tributary to an existing reach (created using an older HEC-RAS version) on the RAS Mapper. On the other hand, I did not get any error when I used HEC-RAS 5.0.7. Does anyone else have the same problem?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at RasMapperLib.EditLayers.StructureLayerEditor.ComputeUSXSDistance(Int32 fid, Single width)
at RasMapperLib.EditLayers.StructureLayerEditor.ComputeAndSetUSDistance(Int32 fid)
at RasMapperLib.EditLayers.StructureLayerEditor.OnFeatureEditorSaving()
at RasMapperLib.EditLayers.FeatureEditor.SaveAndClose()
at RasMapperLib.RASGeometry.StopEditing(Boolean save)
at RasMapperLib.Layer.StopEditingPrompt()
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
PipeServer
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/PipeServer.exe
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
Win32 Version: 4.8.4488.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Utility.Core
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Utility.Core.DLL
RasMapperLib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/RasMapperLib.DLL
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Geospatial.GDALAssist
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Geospatial.GDALAssist.DLL
H5Assist
Assembly Version: 6.0.0.0
Win32 Version: 6.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/H5Assist.DLL
System.IO.Compression
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Hec.Dss
Assembly Version: 1.0.6.0
Win32 Version: 1.0.6.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Hec.Dss.DLL
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
Win32 Version: 4.8.4455.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Geospatial.Core
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Geospatial.Core.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
ParticleTracking
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/ParticleTracking.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
OxyPlot.WindowsForms
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/OxyPlot.WindowsForms.DLL
OxyPlot
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/OxyPlot.DLL
System.Runtime
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
TiffAssist
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/TiffAssist.DLL
System.Globalization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Globalization/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Globalization.dll
System.Net.Http
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
HDF.PInvoke
Assembly Version: 1.10.6.1
Win32 Version: 1.10.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/HDF.PInvoke.DLL
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
BitMiracle.LibTiff.NET
Assembly Version: 2.4.639.0
Win32 Version: 2.4.639.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/BitMiracle.LibTiff.NET.DLL
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Geospatial.IO
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Geospatial.IO.DLL
TiffBinaryReader
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/TiffBinaryReader.DLL
Geospatial.Rendering
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/Geospatial.Rendering.DLL
SharpDX.Direct2D1
Assembly Version: 4.2.0.0
Win32 Version: 4.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/SharpDX.Direct2D1.DLL
SharpDX
CodeBase: file:///C:/Program%20Files%20(x86)/HEC/HEC-RAS/6.2/SharpDX.DLL
—————————————-************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.For example:
<configuration>
<system.windows.forms jitDebugging=”true” />
</configuration>When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.July 13, 2022 at 11:50 am #16007Luis PartidaParticipantJust do it the old school way in the geometry data editor
