The best I can think of:
After you create your 100-year model and run it, create a new plan and steady flow file. From the steady flow editor, go to options, Set Internal Changes in WS and EG. Add multiple RS locations and add every cross section using Known WS. In the value column enter the water surface you want.
To make things easier, from one of the output editors, you could copy the 100-year results to Excel and add “2” or “3” and then copy that result back into the Value column for the known WS.
