Welcome to the RAS Solution › Forums › HEC-RAS Help › Add a Flow Change Location
  • #6749
    Runoff
    Can someone shed some light or point me to a source I can read more about the “add a flow change location” option? I have a steady run that I am setting up. I have considered using this option to incrementally increase the flow along a 10 mile section of a reach for representing the small side tributaries encountered along the reach. Are there some guidelines for when to represent a confluence as a junction vs a flow change location? I will also add that this model will eventually be submitted to FEMA for a CLOMR request. I have read many of the various guidance documents from FEMA trying to find more information for this, but I have not found much regarding the topic yet. Any comments/suggestions are welcome and appreciated.
    #11141
    Lonnie A
    Typical FEMA models will be to just add a flow change locations and not a junction as each reach is usually a separate model.
    #11142
    Lonnie, thanks for your reply. That is helpful.
