Welcome to the RAS Solution › Forums › HECRAS Controller › A VBA Function to list Geometry Storage Area names and types
- This topic has 1 reply, 97 voices, and was last updated 5 years, 9 months ago by gkiers.
June 20, 2020 at 3:35 pm #8245gkiersParticipant
Hi all!
Just started this week with the HEC-RAS Controller…. Since there is no way in to retrieve Storage Area names, I had to write a VBA Function to retrieve their names. This function also checks for the type of Storage Area (SA or 2D Flow). The list of Storage Areas is defined as a Dynamic Array with two rows, Names in Row 0, Type (“SA” or “2D”) in Row 1. The function does not produce output in Excel or something, it creates the array for use in your code.
Since Chris asked us to share our code (and he certainly did! 🙂 ), here it is. Hope I haven’t overlooked something.
The Sub-routine here only added to show how you can use it.
Good luck, Gerrit
Sub UseListStorageAreas()
Dim SA() As String, lNumberTot As Long, lNumberSA As Long, lNumber2D As Long
Dim i As Long‘ Geometry File Program Version= 5.04
SA = ListStorageAreas(“c:\HEC-RAS Examples\Example Data\” & _
“2D Unsteady Flow Hydraulics\BaldEagleCrkMulti2D\BaldEagleDamBrk.g01”)
‘ Geometry File Program Version= 4.00
‘ SA = ListStorageAreas(“c:\AutomateHECRAS\Unsteady Examples\BEAV_STO_PROBLEM.g01”)lNumberTot = UBound(SA, 2) + 1
lNumberSA = 0: lNumber2D = 0
For i = LBound(SA, 2) To UBound(SA, 2)
If SA(1, i) = “SA” Then
lNumberSA = lNumberSA + 1
Else
lNumber2D = lNumber2D + 1
End If
Next iMsgBox “Found ” & lNumberTot & ” areas: ” & lNumberSA & ” storage areas, and ” & _
lNumber2D & ” 2D Flow areas.”End Sub
Function ListStorageAreas(strGeoFile As String) As String()
‘ The list of Storage Areas is defined as a Dynamic Array
‘ with two rows, Names in Row 0, Type (SA or 2D) in Row 1
‘ Arrays are 0-based. By Gerrit Kiers, License CC BY 4.0
Dim strTemp As String, arTemp() As String
Dim strTextLine As String, i As LongOpen strGeoFile For Input As #1
i = 0
ReDim arTemp(1, 0)
Do While Not EOF(1)
Line Input #1, strTextLine
‘Search the geometry text file for the key “Storage Area=”
If InStr(strTextLine, “Storage Area=”) Then
‘ Only process when there is no text ahead of “Storage Area=”
If InStr(strTextLine, “=”) = 13 Then
ReDim Preserve arTemp(1, i)
strTemp = Right(strTextLine, Len(strTextLine) – 13)
strTemp = Left(strTemp, InStr(strTemp, “,”) – 1)
arTemp(0, i) = strTemp
‘Check on “Is2D=” later on, define SA for pre-5.0 Geometry
arTemp(1, i) = “SA”
i = i + 1
End If
End If
‘Now check if the area is 2D
If InStr(strTextLine, “Storage Area Is2D=”) Then
Select Case Right(strTextLine, 1)
Case 0
arTemp(1, i – 1) = “SA”
Case Else
arTemp(1, i – 1) = “2D”
End Select
End If
Loop‘Close the text file
Close #1ListStorageAreas = arTemp
End Function
June 24, 2020 at 8:19 am #13615Chris G.KeymasterReturn-Path:
by sloti1d2t14 (Cyrus 3.3.0-dev0-543-gda70334-fm-20200618.004-gda703345) with LMTPA;
Wed, 24 Jun 2020 00:19:21 -0400
X-Cyrus-Session-Id: sloti1d2t14-1592972361-2709773-2-14010834310264386019
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-sender-reputation: 500 (none)
X-Spam-score: 0.1
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, ME_SENDERREP_NEUTRAL 0.001,
MIME_QP_LONG_LINE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
RCVD_IN_MSPIKE_H3 0.001, RCVD_IN_MSPIKE_WL 0.001, SPF_HELO_NONE 0.001,
SPF_PASS -0.001, URI_HEX 0.1, LANGUAGES en, BAYES_USED none,
SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.216.54′, Host=’mail-pj1-f54.google.com’, Country=’US’,
X-Spam-charsets: plain=’utf-8′, html=’utf-8′
Received: from mx3 ([10.202.2.202])
by compute1.internal (LMTPProxy); Wed, 24 Jun 2020 00:19:21 -0400
Received: from mx3.messagingengine.com (localhost [127.0.0.1])
by mailmx.nyi.internal (Postfix) with ESMTP id C23991960115
for; Wed, 24 Jun 2020 00:19:20 -0400 (EDT)
by mx3.messagingengine.com (Authentication Milter) with ESMTP
id E86513B0517;
1592972360; b=hh6DUgJPkMdoJBnz5Mu87F2FlxbZApMMn6H0o9eiDXll/KCmC2
sJ70Tbs/xDgehOgWZORsyesl30ZugCktVv8jwTBj+U32a9+LBIBkfH7PTDhcVzNY
YD/Fe37KKf6koYPvlFVWuKr6amdq1A2bEJviLIdH3cvxNCJQ6ilWAsRExg8F2iSm
kqvE8Jfaru5yJ1kRg2b9m3ySXCFBuXjaseGckmylm1uURr2R+pE6ZmR8TUdTTukV
uybzF3W8T9xRpN2IP4fdtSnNkb1wGOU7IslXwxmCj3rNFq5ZuDkDzLH2Jlab3OHS
8MnGxwcjFOH3rTx2Ld59s1rt9ushVJ1IaipA==
messagingengine.com; h=content-type:content-transfer-encoding
:from:mime-version:subject:date:message-id:references
:in-reply-to:to; s=fm3; t=1592972360; bh=w/UaStigCm8dgDKKHJsOMts
gu8ykM30fNBB78088deU=; b=FaU9ibvxS2/A/B2zTLlf3CHFjfVrr0Yr6GF/dMF
Ti2BGN6f+2nUNRGi7Az6RXeOnGjiTJjxnKZywSYKZxXRfqR4w/QXxE9xWGiZH4AL
ugZMFY5KXnK8EuRBGzT6CfLuGNtJeluPDU9ooVY1y7Yl1jZ6FRZxBIecOOCHwIVL
Ni1ymyiur0i+lES//l3l8kKkIE4AI+K/PFyVHpfvClutrrlTcXGRT4BiVdBg+hWX
MoXLHjQDDeA/dCi/o0+SaW8uufdTcspI2cdz6gbkqEzUdpIN0T/oI9oK+HULQrF/
T9XLZj3rTz+OYUOOFcd1O0xY++lmhJlPPWYwIXPyh/IoSoA==
ARC-Authentication-Results: i=1; mx3.messagingengine.com; arc=none (no signatures found);
bimi=none (Domain is not BIMI enabled);
[email protected] header.b=hq3BOOG3 header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.216.54 (mail-pj1-f54.google.com);
spf=pass [email protected]
smtp.helo=mail-pj1-f54.google.com;
[email protected] header.b=CCHFJmB8;
x-ptr=pass smtp.helo=mail-pj1-f54.google.com
policy.ptr=mail-pj1-f54.google.com;
(MX Records found: alt4.gmail-smtp-in.l.google.com,alt3.gmail-smtp-in.l.google.com,alt1.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com,alt2.gmail-smtp-in.l.google.com);
smtp.bits=128/128;
x-vs=clean score=0 state=0
Authentication-Results: mx3.messagingengine.com;
smtp.bits=128/128;
xhdGUvTmFtbFNlcnZsZXQuanRwP21hY3JvPXVuc3Vic2NyaWJlX2J5X2NvZGUmbm9kZT0x
MTg0JmNvZGU9ZEdobGNtRnpjMjlzZFhScGIyNUFaMjFoYVd3dVkyOXRmREV4T0RSOE1URT
NORGc1TkRneE5RPT0
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduhedrudekiedgkedvucetufdoteggodetrfdotf
fvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgfnhhsuhgsshgtrhhisggvpdfu
rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucenucfjughrpegtgffhgg
fufffkfhgjvffosegrjehmrehhtdejnecuhfhrohhmpefvhhgvucfttefuucfuohhluhht
ihhonhcuoehthhgvrhgrshhsohhluhhtihhonhesghhmrghilhdrtghomheqnecuggftrf
grthhtvghrnhepffeuvddvveduudeujeevieffffefueetffeileeguefhteejkeeftedt
teekieefnecuffhomhgrihhnpehnrggssghlvgdrtghomhenucfkphepvddtledrkeehrd
dvudeirdehgedpjedurdduleefrddvfeeirdduudefnecuvehluhhsthgvrhfuihiivgep
tdenucfrrghrrghmpehinhgvthepvddtledrkeehrddvudeirdehgedphhgvlhhopehmrg
hilhdqphhjuddqfhehgedrghhoohhglhgvrdgtohhmpdhmrghilhhfrhhomhepoehthhgv
rhgrshhsohhluhhtihhonhesghhmrghilhdrtghomhequcfukfgkgfepuddujeelle
X-ME-VSScore: 0
X-ME-VSCategory: clean
Received-SPF: pass
receiver=mx3.messagingengine.com;
identity=mailfrom;
client-ip=209.85.216.54
Received: from mail-pj1-f54.google.com (mail-pj1-f54.google.com [209.85.216.54])
by mx3.messagingengine.com (Postfix) with ESMTPS
Received: by mail-pj1-f54.google.com with SMTP id m2so556591pjv.2
for; Tue, 23 Jun 2020 21:19:20 -0700 (PDT)
d=gmail.com; s=20161025;
h=content-transfer-encoding:from:mime-version:subject:date:message-id
:references:in-reply-to:to;
bh=w/UaStigCm8dgDKKHJsOMtsgu8ykM30fNBB78088deU=;
b=hq3BOOG3o3rGuv6ppheY1WQkfVzQi7P5hy/Y0OCPDHHuR3Fpr5Y9LDDM1XT0KkQ/xe
sgQTxFqhmA8PqaxCsc5L8+nqtuskB/I+rmoWcXERwAamFLk4Er078yBasqofXI3k+UpJ
GI2JUHK2lUuJfmx6DYgHVIleiVFC+TBr1mx4Vyjd4OEZlqDYzNVqmyAtdnU+lWiIl88P
nj+45nOcV5aEx262txyBTbooPGYRrQWsojrYWDBKuUI66TJyNXc8GXmo0h27qeKRmOlA
U4W1HdqL9K8XuGa4X9vg6RPY4kRw2Gd7Ee6ZX5qNIIhyUr6jgqPjoJJvZZipfKFlwRxH
upQw==
d=1e100.net; s=20161025;
h=x-gm-message-state:content-transfer-encoding:from:mime-version
:subject:date:message-id:references:in-reply-to:to;
b=CCHFJmB8s6ilviJzAOk2dlp8BzIdOxHB6vF9POajSyZNIorcFKaK7Eot9ww6eGOxd6
U3BuVBFspJk5ezrwISqCmu8umAIc5tTCxH2cnrXnMnVkvJMFAgZOmfrpcJEYlevWLVdY
PR6oztJEbAAmKepRO1B9Som0vmT9a/2gJzwXgmWKtWJnS3ud0wkkcBsxQC832GwoK1um
4y94M1l4q2Fe9GPSKr1Ygpgxz0SGmUwud/ovrnfRnrEL7AGC9ugSSLUfEXHHPihXtYs+
KZFwDpROANFzAN65ZhtOadjOJX+ho8zR9eRDQhgJ1SHTHm8mWm6m4wJMqtgFoee4kABb
bKBw==
X-Gm-Message-State: AOAM530mlvmTa1seFySYoDcH/ro047EjQTVLl0LFz9KIsMmMrDf8LhP/
H2GfGBXORVYmcai9glwM/TuXqqoX
X-Google-Smtp-Source: ABdhPJzVdF8KsIjCza0WBU3K7XjNawi0LYY6m9CLVoMq5kWcIw+PJInJboVohUjB+CPcJ+VVcJF62Q==
X-Received: by 2002:a17:90b:4905:: with SMTP id kr5mr7199984pjb.100.1592972358134;
Tue, 23 Jun 2020 21:19:18 -0700 (PDT)
Received: from [192.168.1.12] (c-71-193-236-113.hsd1.or.comcast.net. [71.193.236.113])
by smtp.gmail.com with ESMTPSA id s13sm19096826pfc.136.2020.06.23.21.19.16
for
(version=TLS1_3 cipher=TLS_AES_128_GCM_SHA256 bits=128/128);
Tue, 23 Jun 2020 21:19:17 -0700 (PDT)
Content-Type: multipart/alternative; boundary=Apple-Mail-DD33FA7C-9795-4C3E-A89D-19746CC81007
Subject: Re: A VBA Function to list Geometry Storage Area names and types
Date: Tue, 23 Jun 2020 21:19:15 -0700
To: “gkiers [via HEC-RAS Help]”
X-Mailer: iPhone Mail (17F80)–Apple-Mail-DD33FA7C-9795-4C3E-A89D-19746CC81007
Content-Type: text/plain;
charset=utf-8
Content-Transfer-Encoding: quoted-printableThanks Gerrit!
Sent from my iPhone
> On Jun 20, 2020, at 4:35 AM, gkiers [via HEC-RAS Help]
wrote:
>=20
> =EF=BB=BF Hi all! Just started this week with the HEC-RAS Controller…. S=
ince there is no way in to retrieve Storage Area names, I had to write a VBA=
Function to retrieve their names. This function also checks for the type of=
Storage Area (SA or 2D Flow). The list of Storage Areas is defined as a Dyn=
amic Array with two rows, Names in Row 0, Type (“SA” or “2D”) in Row 1. The f=
unction does not produce output in Excel or something, it creates the array f=
or use in your code. Since Chris asked us to share our code (and he certainl=
y did! 🙂 ), here it is. Hope I haven=E2=80=99t overlooked something. The S=
ub-routine here only added to show how you can use it. Good luck, Gerrit
> Dim SA() As String, lNumberTot As Long, lNumberSA As Long, lNumber2D As L=
ong
> Dim i As Long
> =20
> ‘ Geometry File Program Version=3D 5.04
> SA =3D ListStorageAreas(“c:\HEC-RAS Examples\Example Data\” & _
> “2D Unsteady Flow Hydraulics\BaldEagleCrkMulti2D\BaldEagleDamBrk.g01=
> ‘ Geometry File Program Version=3D 4.00
> ‘ SA =3D ListStorageAreas(“c:\AutomateHECRAS\Unsteady Examples\BEAV_STO_=
PROBLEM.g01”)
>=20
> lNumberTot =3D UBound(SA, 2) + 1
> lNumberSA =3D 0: lNumber2D =3D 0
> For i =3D LBound(SA, 2) To UBound(SA, 2)
> If SA(1, i) =3D “SA” Then
> lNumberSA =3D lNumberSA + 1
> Else
> lNumber2D =3D lNumber2D + 1
> End If
> Next i
>=20
> MsgBox “Found ” & lNumberTot & ” areas: ” & lNumberSA & ” storage areas,=
and ” & _
> =20
>=20
> End Sub
>=20
>=20
> =20
> =20
> i =3D 0
> Do While Not EOF(1)
> ‘Search the geometry text file for the key “Storage Area=3D”
> If InStr(strTextLine, “Storage Area=3D”) Then
> ‘ Only process when there is no text ahead of “Storage Area=3D”
> If InStr(strTextLine, “=3D”) =3D 13 Then
> strTemp =3D Right(strTextLine, Len(strTextLine) – 13)
> strTemp =3D Left(strTemp, InStr(strTemp, “,”) – 1)
> arTemp(0, i) =3D strTemp
> ‘Check on “Is2D=3D” later on, define SA for pre-5.0 Geometry
> arTemp(1, i) =3D “SA”
> i =3D i + 1
> End If
> End If
> If InStr(strTextLine, “Storage Area Is2D=3D”) Then
> Case 0
> arTemp(1, i – 1) =3D “SA”
> Case Else
> arTemp(1, i – 1) =3D “2D”
> End Select
> End If
> Loop
> =20
> Close #1
>=20
> ListStorageAreas =3D arTemp
>=20
> End Function
>=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/A-VBA-Function-to-list-Geometry-=
Storage-Area-names-and-types-tp8903.html
> To start a new topic under HECRAS Controller, email ml+s1091112n1184h88@n5=
.nabble.com=20
> To unsubscribe from HECRAS Controller, click here.
> NAML–Apple-Mail-DD33FA7C-9795-4C3E-A89D-19746CC81007
Thanks Gerrit!
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: quoted-printableSent=
from my iPhoneOn Jun 2=
0, 2020, at 4:35 AM, gkiers [via HEC-RAS Help] <[email protected]=
bble.com> wrote:=EF=BB=BFHi all!
Just started this week with the HEC-RAS Controller…. Since there is no way=
in to retrieve Storage Area names, I had to write a VBA Function to retriev=
e their names. This function also checks for the type of Storage Area (SA or=
2D Flow). The list of Storage Areas is defined as a Dynamic Array with two r=
ows, Names in Row 0, Type (“SA” or “2D”) in Row 1. The function does not pro=
duce output in Excel or something, it creates the array for use in your code=
.Since Chris asked us to share our code (and he certainly did! :-) ), here it=
is. Hope I haven=E2=80=99t overlooked something.=20The Sub-routine here only added to show how you can use it.
Good luck, Gerrit=20
Sub UseListStorageAreas() Dim SA() As String, lNumberTot As Long, lNumberSA As Long, lNumber2D As Lo= ng Dim i As Long =20 ' Geometry File Program Version=3D 5.04 SA =3D ListStorageAreas("c:\HEC-RAS Examples\Example Data\" & _ "2D Unsteady Flow Hydraulics\BaldEagleCrkMulti2D\BaldEagleDamBrk.g01")= ' Geometry File Program Version=3D 4.00 ' SA =3D ListStorageAreas("c:\AutomateHECRAS\Unsteady Examples\BEAV_STO_PR= OBLEM.g01") lNumberTot =3D UBound(SA, 2) + 1 lNumberSA =3D 0: lNumber2D =3D 0 For i =3D LBound(SA, 2) To UBound(SA, 2) If SA(1, i) =3D "SA" Then lNumberSA =3D lNumberSA + 1 Else lNumber2D =3D lNumber2D + 1 End If Next i MsgBox "Found " & lNumberTot & " areas: " & lNumberSA & " s= torage areas, and " & _ lNumber2D & " 2D Flow areas." =20 End Sub Function ListStorageAreas(strGeoFile As String) As String() ' The list of Storage Areas is defined as a Dynamic Array ' with two rows, Names in Row 0, Type (SA or 2D) in Row 1 ' Arrays are 0-based. By Gerrit Kiers, License CC BY 4.0 Dim strTemp As String, arTemp() As String Dim strTextLine As String, i As Long =20 Open strGeoFile For Input As #1 =20 i =3D 0 Do While Not EOF(1) Line Input #1, strTextLine 'Search the geometry text file for the key "Storage Area=3D" If InStr(strTextLine, "Storage Area=3D") Then ' Only process when there is no text ahead of "Storage Area=3D" If InStr(strTextLine, "=3D") =3D 13 Then ReDim Preserve arTemp(1, i) strTemp =3D Right(strTextLine, Len(strTextLine) - 13) strTemp =3D Left(strTemp, InStr(strTemp, ",") - 1) arTemp(0, i) =3D strTemp 'Check on "Is2D=3D" later on, define SA for pre-5.0 Geometry arTemp(1, i) =3D "SA" i =3D i + 1 End If End If 'Now check if the area is 2D If InStr(strTextLine, "Storage Area Is2D=3D") Then Select Case Right(strTextLine, 1) Case 0 arTemp(1, i - 1) =3D "SA" Case Else arTemp(1, i - 1) =3D "2D" End Select End If Loop =20 'Close the text file Close #1 ListStorageAreas =3D arTemp End Function=09
=09
=09
If you reply to this email,=
your message will be added to the discussion below:
To start a new topic under HECRAS Controller, email ml+s109=
[email protected]
NAML=
–Apple-Mail-DD33FA7C-9795-4C3E-A89D-19746CC81007–
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)- You must be logged in to reply to this topic.
