• Blog
  • Book
  • Forum
  • Videos
Extracting Water Surface Elevation for Levee Profile Lines
This article shows how to fix the "Weir Submergence Not Set" error.
Read More
Search for Posts
Welcome to the RAS Solution
The Author
Events
Start Date: March 12, 2025
End Date: April 16, 2025
Translate
Follow Me
Links
"BREAKING THE HEC-RAS CODE"
Subscribe:
RSS Feed
Tags:
-1.#INF,
.prj,
1D,
1D 2D,
2-D,
2D,
2D Area Connections,
3D,
3D Printed Terrain,
3D Printer,
3D Viewer,
3DV-Flo,
4.1,
5.0,
5.0.2,
5.0.3,
5.0.4,
5.0.5,
5.0.6,
5.0.7,
5.1,
6.0,
6.x,
7.0,
Adjust Elevations,
Admin,
Aerial,
Animation,
Application,
Applications Guide,
ArcGIS,
ASCE,
Astoria,
Atlanta,
Attenuation,
Auckland,
Australia,
Australian Water School,
AutoCAD,
Automation,
Backwater,
bank stations,
Barcelona,
bathymetry,
Beer,
Ben Cary,
Benchmarking,
Bend,
beta,
Boise,
Bolivia,
book,
Bosnia,
Boston,
Boundary Conditions,
Breach Parameters,
Breaking the HEC-RAS Code,
Breaklines,
Bridge,
Bridges,
Brisbane,
Broad Crested,
BSTEM,
Bug,
Building,
California,
Cameron Ackerman,
Canal,
Casulli,
Cell,
cell size,
Check Gates,
Chehalis,
Chile,
Chris Goodell,
Class,
Coal,
Code,
Colin Thorne,
Columbia River,
Column,
Combine,
Comments,
Computation,
Computation Level Output,
Computer,
Concepcion,
Condit,
Conference,
Connection,
Conservation of Mass,
Contraction,
Control,
convergence,
Conveyance,
Coordinate System,
Cores,
Courant,
Course,
Craft Brew Alliance,
Crash,
Critical Creek,
critical depth,
Cross Section Points Filter,
Cross Sections,
CRREL,
Culvert,
Culverts,
Cutlines,
Dam,
Dam Breach,
Dam Break,
Dam Failure,
Dam Safety,
Date,
Datum,
David Markwood,
Debug,
deck,
Deleting,
DEM,
digital elevation model,
direct precipitation,
Discharge,
Discharge Coefficient,
Divisors,
Download,
downstream boundary,
Drawdown,
Dry Bed,
DSS,
Dynamic,
Earthquake,
Eddy,
EDI,
Edit,
Efficiency,
Emergency Management,
Energy,
Energy Balance,
Engineer,
Erosion,
Errata,
Error,
errors,
ESRI,
Estuary,
Euro-RAS,
Europe,
Example Projects,
excavation,
Exceedance,
Excel,
Exception,
Expansion,
Fanno,
Features,
File Management,
Filter,
Finite Difference,
Finite Volume,
Fish Passage,
Fishway,
FLO2D,
Flood,
flood visualization,
Flood Warning,
Floodplain,
Florida,
Flow,
Flow Data,
Flow distribution,
Flow Lines,
Flow Patterns,
flow regime,
Flume,
FMA,
Forecasting,
forum,
fragmentation,
Fragmented Inundation,
France,
Freeboard,
Froude,
full momentum,
G2C,
Galileo,
Gary Brunner,
Gary Wolff,
Gate,
Gates,
Geometry,
geometry file,
GeoRAS,
georeference,
georeferenced,
Geospatial,
GeoTiff,
GIS,
Google Earth,
Grady Hillhouse,
Graphics,
Green and Ampt,
Grid,
Grids,
Guidance,
Guidelines,
Hager,
Hard Drive,
HBox,
HDF5,
HEC,
HEC-RAS,
HEC-RAS Class,
HEC-RAS. 5.0.6,
HECRASController,
HEIS,
Help,
Hotstart,
HTab,
Hydraulic Jump,
Hydraulic Modeling,
Hydraulic Radius,
Hydraulics,
hydrograph,
Hydrology,
Hydropower,
Ice,
ICEWaRM,
Imagery,
Images,
Implicit,
Inconsistency,
Ineffective flow,
Infiltration,
inflow,
Initial and Constant,
Initial Conditions,
Inline Structure,
input,
Instability,
installation,
internal,
International,
Interpolation,
Intersect,
Intro,
Inundation,
Irrigation,
iterations,
Jaison Renkenberger,
Jam,
Jarrett,
JBA,
Juha Aaltonen,
Junctions,
Kevin Denn,
Kindsvater-Carter,
Kleinschmidt,
KML,
Known Issues,
Krey,
Krey Price,
Labyrinth,
Language,
Lateral Structure,
Lateral Structures,
Layer,
Leaking,
Levee,
Level Pool,
LiDAR,
lifting,
Limitations,
LinkedIN,
London,
Lonnie Anderson,
LPI Method,
Mac In Black,
Mamore,
Manage Results Maps,
Manager,
Manning's,
manual,
Map,
mapping,
Mark Forest,
Mark Jensen,
Mars,
Marty Teal,
Max WS,
McBreach,
Measuring Tool,
Melbourne,
Merge,
Mesh,
Message,
Michael Link,
MIKE21,
Mississippi,
Missoula Flood,
MIT,
Mixed Flow,
Model,
Momentum,
Monte Carlo,
Multiple Cross Sections,
Muncie,
Munich,
Nature,
NAVD88,
Negative Flows,
New Features,
New Position,
New Users,
New Zealand,
Newsletter,
NGVD29,
NHEC,
NHWC,
NOAA,
Non-Newtonian,
normal depth,
Nuisance Cells,
Numerical Model,
Ogee,
Online,
Operations,
Optimization,
Option,
Oregon,
OSGeo.GDAL.GdalPINVOKE,
Outlet RC,
output,
Overflow Gate,
Override,
Overtopping,
Pan,
Paris,
Particle Tracking,
pdf,
Peak Flow,
Peak Stage,
Performance,
permanent,
pH Experiment,
Photo,
Piping,
Plot,
Portland,
post-processing,
PowerPoint,
Practical Engineering,
precip,
Precipitation,
Preprocessing,
Presentation,
Pressure,
Price,
Probabilistic,
Processing,
Profile,
Profile Lines,
Programming,
Project,
Projection,
Projector,
Pub and Grub,
Pumps,
Q Weir,
Quasi Unsteady,
Radar,
rain on grid,
Rainfall,
RAM,
RAS,
RAS API,
RAS DLL,
RAS Mapper,
RAS Results,
RAS2D,
RASMapper,
raster,
RASter Calculator,
Rasters,
Rating Curve,
Reach,
Reach Lines,
References,
refinement region,
Regional,
Regions,
Rehbock,
Release,
Release Notes,
Report,
Reservoirs,
Results,
risk,
Risk Analysis,
River,
River Ice,
River Restoration Northwest,
routing,
Rufener,
Rules,
Run Times,
Santiago,
Sarajevo,
SCADA,
Script,
Scripting,
SCS,
Sean Welch,
Search,
Sediment,
Sediment Transport,
Self Rescue Zone,
Service Event,
Settings,
Seville,
Shapefiles,
Sharp Crested,
shortcut,
Side Channel,
skew angle,
slope,
slow model runs,
Slurry,
Solution Scheme,
South Africa,
Spacing,
Spain,
Spatial,
Spatial Precipitation,
Spatial Reference,
spatialreference.org,
Speed,
Spillway,
Spillways,
Spine,
Split,
SSD,
St. Venant,
Stability,
Stage,
Stanford Gibson,
Static,
Station-Elevation Points,
Steady,
Steve Daly,
Storage,
Storage Area,
Storage Areas,
Storage-Elevation Curve,
Stored Maps,
Structured,
Subcritical,
Subgrid Bathymetry,
Submergence,
Suggestions,
Sunny Day,
Supercritical,
surface,
Surface Water Solutions,
Survey,
Sydney,
Table,
Tailwater,
Temperature,
Terrain,
text file,
The RAS Solution,
Theory,
Theta,
Tides,
Tigard,
Time,
Time Series,
time step,
Time Steps,
Timesteps,
Timing,
Tip,
Tips and Tricks,
topography,
Training,
Tributary,
Troubleshooting,
TUFLOW,
TUM,
Tunnel,
Turbines,
Turbulence,
TW,
Two-Dimensional,
UCSC,
Uncertainty,
Unstable,
Unsteady,
Unsteady Flow,
Unstructured,
UTM,
Validation,
VBA,
Vectors,
Velocity,
Verification,
Version,
VERTCON,
Vertical Walls,
Video,
Viscosity,
Visual Basic,
Vladimir Moya,
Vodcast,
Volume,
Wahlin,
Washington,
Water Surface Profile,
waves,
Web,
Web Imagery,
Webinar,
Wedge Depression,
Weight,
Weir,
Weir Coefficient,
Weir Equation,
WEST Consultants,
Wetted Perimeter,
White Salmon,
Widmer,
wind,
Windows 8,
WKT,
Woidt,
World Cup,
World File,
wormhole culverts,
YouTube,
Zero Height,
zoom,
Show All Tags
Show Less Tags
RAS Solution
Kleinschmidt
141 Main Street
Pittsfield, ME 04967
888-224-5942
[email protected]
  • Sitemap
  • Privacy Policy
