Read More
I am working on a dam breach project where I’m trying to simplify a complicated model with dozens of tributaries and storage areas. In the process, I’m converting a few tributaries into storage areas (which are surrounded by other storage areas). For example, I want to convert the reach below (from 5.43 to 0.55) to […]
Read More
Advanced Rules for Unsteady Flow
This is a great presentation put together by Mr. Steven Piper of the Hydrologic Engineering Center that discusses in detail the use of “Rules” at inline structures.  Dr. Michael Gee forwarded this presentation to me after seeing some discussion on the forum about the use of Rules for inline structures.  Thanks for the suggestion Dr. […]
Read More
Read More
How to use a Storage Area to define a Reservoir.
It’s a little confusing, and not really directly covered in the manuals anywhere. But I get this question a lot. “How do use a Storage Area to define my reservoir in RAS?” First of all, make sure using a Storage Area and level pool routing is an appropriate way to model your reservoir. This is […]
Read More
Stability Issues with Storage Areas
Storage Areas in unsteady RAS are notoriously stable. That’s why we like to use them. Get the water out of the 1-d St. Venant unstable environment, into the 0-d stable continuity environment. However, I recently discovered a problem with storage areas that could cause your model to go unstable, or at least chug along slowly […]
Read More
