The No-Rise Surprise
First thing you do is specify that you want to drop your lateral flows into cross sections. Then set your upstream TW river station (the downstream one will be greyed out).
Then, go to the Weir/Embankment editor for your lateral structure. At the bottom left, you’ll see weir stationing reference. Select TW flow goes: “over multiple XS’s”. Then on the right hand side you’ll see a table for specifying weir stationing for your TW cross sections.
