HEC-RAS 5.0 Official Release is Available!!!
Written by Chris Goodell | March 4, 2016
The wait is over!  Finally the official release of HEC-RAS Version 5.0 is here.  You can download it from the HEC website at http://www.hec.usace.army.mil/software/hec-ras/
If the download from the HEC website is slow, you can also download it from here:
https://drive.google.com/file/d/0B0bpiyLiUeRXTy1pdUNralMzZ1U/view?usp=sharing (207 MB,  Installation package without example problems)
https://drive.google.com/file/d/0B0bpiyLiUeRXNGllMlE5V1dmQmM/view?usp=sharing (538 MB, Installation package with example problems)
This new version also comes with updated manuals (User’s Manual, Hydraulic Reference Manual, and Applications Guide), as well as a new 2D Modeling Manual.
Enjoy and good luck!!!
  1. Stéphane GAIJI
    on March 4, 2016
    Finally … These last days I was beginning to despair
  2. Mikołaj Olbrych
    on March 4, 2016
    Hello Stephane and Chris 😉 I will test it with my current embankment breach project
  3. Unknown
    on March 4, 2016
    I have noticed that I am unable to run any HEC-RAS version beyond 4.1 (all of the beta versions as well as this version 5.0) when I have FLO-2D installed on the same computer. When running HEC-RAS, this error occurs, "HEC-RAS cannot start because there are hdf5 libraries in your Windows system folder(s). It is poor practice to copy application libraries into the system folder because of the order that Windows loads libraries used by programs. Delete hdf5*.dll files from:
    C:Windowssystem32
    C:WindowsSysWOW64
    And then start HEC-RAS again.
    HEC-RAS will now exit."
    If I follow these instructions, RAS will work but FLO-2D will not.
    Currently our solution is to run one software on the main computer and run the other on a virtual machine.
  4. arkads1
    on March 4, 2016
    Hi all. I used the last beta in my last job
  5. Gerinc
    on March 5, 2016
    Nice!
  6. Phuong Mai
    on March 6, 2016
    Nice stuff! Thank you for the post.
    I have a quick question – We should have depth-vs-time graphs everywhere within a rain-on-grid 2D domain area, even few millimetres, but why there are many points we just have ZERO depth graphs?
  7. Martin Maretta
    on March 7, 2016
    Nice. Do you plan to publish EA benchmark test?
  8. cy
    on March 7, 2016
    Were there changes from the Aug 2015 beta to the final release?
  9. cy
    on March 7, 2016
    Were there changes from the Aug 2015 beta version to the final release?
  10. Chris Goodell
    on March 7, 2016
    Yes. A few new items, but mostly bug fixes and an improvement to the full momentum solver for 2D.
  11. Chris Goodell
    on March 7, 2016
    No, but HEC might.
  12. Chris Goodell
    on March 7, 2016
    Not sure. I haven't tested that yet.
  13. Phuong Mai
    on March 7, 2016
    Just found the answer. Go to RAS Mapper/Tools/Render Mode Options, then select Horizontal (As computed), set Plot Tolerance to zero, we can see the water everywhere in the 2D domain! Chhttp://hecrasmodel.blogspot.com/logout?d=https://www.blogger.com/logout-redirect.g?blogID%3D1675184707067447729%26postID%3D636433072087455954eers.
  14. Eric
    on March 9, 2016
    When I open up the geometric data editor it now has a grid of numbers completely covering the model extents, and I can't figure out how to turn the numbers off. I turned everything off in View Options and that didn't do it. Any thoughts; what am I missing?
  15. Chris Goodell
    on March 9, 2016
    Could it be a map layer in the background images? Other than that and the view options, not sure why that is happening. Do you know what the numbers represent?
  16. Eric Clyde
    on March 10, 2016
    It appears to be associated with the terrain, but I have been working with this same terrain and project for months with no similar problem.
  17. Margaretha Titi
    on March 16, 2016
    Hello Chris, can I install this 5.0 final along with the previous beta or 4.1 in the same drive C?
    Thanks for answering and have a good day!
  18. Chris Goodell
    on March 16, 2016
    Yes. I have 4.1 and 5.0 on my computer. Both work. I think you can even have the beta version on there with 5.0.
  19. h2othomas
    on April 5, 2016
    Are there issues with installing on Windows 10 Pro? Thanks!
  20. h2othomas
    on April 6, 2016
    Hi Chris, are there any issues with Windows 10? Thanks!
  21. Chris Goodell
    on April 6, 2016
    I don't know of anything specific. But what I do know is that HEC did not test RAS 5.0 with Windows 10. So there are likely to be some quirks, at the least.
  22. Stéphane GAIJI
    on April 7, 2016
    HECRAS 5 work fine on my Windows 10 Home
  23. Phuong Mai
    on April 7, 2016
    I've installed it onto my Windows 10 Pro machine, and haven't found any issues so far.
  24. Roi FACAL VAZQUEZ
    on October 20, 2016
    same error
  25. Rohit
    on May 2, 2018
    Hi Chris, Just installed 5.0.4, all works fine but unable to open RAS Mapper although 5.0.3 version is working fine. I have Win 7, is anyone here facing same issue?
  26. Chris Goodell
    on May 3, 2018
    That’s not good! You may want to let HEC know if you can’t resolve the issue.
nine + six =
