The No-Rise Surprise
Written by Chris Goodell, P.E., D. WRE | Kleinschmidt Associates
This is a summary from a paper (Goodell,Christopher;Wahlin, Brian. “Dynamic and Level Pool Reservoir Drawdown: A Practical Comparison for Dam Breach Modeling.” 33rd IAHR Congress Proceedings, Vancouver Canada, 2009) on level pool versus dynamic reservoir drawdown for dam breach modeling. In RAS you can define your reservoir with a series of cross sections (which uses dynamic routing) or a storage area (which uses level pool routing). Dynamic routing is generally assumed to be more accurate, but the size and shape of a reservoir can sometimes make level pool reservoir adequate.
A key component to dam breach modeling is the reservoir drawdown. This has a significant impact on the magnitude and shape of the breach outflow hydrograph, and ultimately the extent of flood inundation in the downstream reach. Drawdown of the reservoir can be modeled with the precise and physically correct dynamic routing method, which uses the full St. Venant equations of Conservation of Mass and Conservation of Momentum. However, this requires detailed bathymetric data for the reservoir, which is frequently very difficult and expensive to obtain for existing reservoirs. Furthermore, dynamic routing is complex and prone to numeric instabilities. A level pool drawdown is a more simplistic, numerically stable approach that can be used successfully under certain circumstances and requires only a simple stage-storage curve for the reservoir.
Two primary characteristics emerge as indicators of a given reservoir’s ability to be described by a level pool analysis. The Compactness Factor, Fc, is simply the ratio of the dam height (H) to the reservoir length (L). The longer and shallower the reservoir, the lower the Compactness Factor and the more the reservoir acts like a river during its drawdown. Thus dynamic routing would be more appropriate in this situation. Short, relatively deep reservoirs are more compact, have a larger Fc value, and can be adequately described using a level pool analysis.
The Translation Factor, Ft, describes the relationship between the speed of the breach development and the ability of the reservoir to supply water to replace the water leaving through the breach. The easier the reservoir can deliver water to the breach, the more it can be described by a level pool analysis. Fast breach developments and long reservoirs are more appropriate to be modeled by dynamic routing. The Translation Factor is computed as:
Ft = ct/L
Where: c = shallow water wave celerity =
d = representative reservoir depth.
and t = time.
A third parameter can be used to help graphically display the results of the various simulations. The Drawdown Number, Dn, is defined as the product of the Translation Factor and the Compactness Factor.
It becomes apparent that for high Drawdown Numbers, the level pool analysis produces results very close to dynamic routing. By enveloping the data points, a 5% threshold Drawdown Number is shown to be 0.41. That means that a reservoir with a Drawdown Number of 0.41 or greater will produce peak outflow results within 5% of a dynamic routing simulation. The 10% threshold Drawdown Number of 0.24 is also indicated on the plot.
You can see the full paper in the referenced proceedings.
